Left front caliper won't release
Old Jul 12, 2001 | 11:22 AM
ATOMonkey's Avatar
Ok here it is. Sometimes after I brake the left front caliper won't release. It doesn't happen all the time either. I've replaced that caliper twice and installed a new proportioning valve. I've checked the hardlines and there is nothing wrong with them. An X-GM employee told me that sometimes the caliper will mechanically bind which is what looks like is happening. Any ideas? Has this happened to anyone else?
'87 Bird 350 .060 over 700R4 + Lots more
Old Jul 12, 2001 | 11:59 AM
FloridaRacer's Avatar
have you replaced rubber line that goes to the caliper yet?
FloridaRacer.com
[This message has been edited by FloridaRacer (edited July 12, 2001).]
Old Jul 12, 2001 | 01:15 PM
ATOMonkey's Avatar
The only part of the hydraulic system that I haven't replaced is the master cylinder and the soft lines. I think the next thing after I replace those(or the first thing) is the allen bolts that hod the caliper to the bracket. I think that they are flexing enough to cause problems.
Old Jul 12, 2001 | 10:55 PM
orange rocket's Avatar
Is the bolt that holds the soft line to the caliper aligned correctly? Is it just on certain types of braking??
Old Jul 12, 2001 | 11:34 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'd have to put a vote towards the rubber line being the culprit as well.
The mind is like a parachute, it only works when its open
Old Jul 13, 2001 | 05:29 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
My brother changed his rubberlines and it solved his problems.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood, High-rise Z-28 spoiler,
Hooker super comp headers,dual 3" exhaust,two 1-chamber Flomasters,Iroc sway bars,wonderbar,140 Iroc gauge cluster,Iroc steering box,Auto meter gauges,dual guage A-piller pods,open air filter,AFPR,smog delete
TBI mods,180* thermostat,
383 stroker in the works
President-Austin 3rd Gen F-body c.c.
Austin 3rd Gen F-body c.c. message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Jul 16, 2001 | 02:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Agreed; the rubber line... replace both fronts at the same time; otherwise, you'll surely be doing this job again on the other side soon!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jul 16, 2001 | 03:13 PM
jm91rs's Avatar
yup, less than a month ago that solved my problem. change those lines.
Old Jul 17, 2001 | 01:32 PM
Z28Man's Avatar
Here is what happened to me. In the rubber lines there is a liner, when these lines get old that lining acts like a flap. This flap will hold the pressure causing the caliper to continue to brake. Replace the rubber lines! It's easy if you use heat to get the connections loose, don't bend the steel lines or your FUBAR!
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
