Would replacing pitman arm reduce play?
Old Jul 26, 2001 | 09:21 AM
matt_at_ttu's Avatar
I've recently replaced most components of my steering linkage(center link, idler arm, inner and outer tie rods, and the adjusting sleeves) and it fixed most of the play in my steering. But there is still a little bit of play-not enough though to replace the steering box. I wouldn't think that the pitman arm would be that significant, but I figured I would get anyone else's opinion it. Thanks,
matt
1988 Formula 350
-TES headers
-Edelbrock cat-back
-Accel 8mm wires
-Accel Electronic Super Coil
-K&N filter
Old Jul 26, 2001 | 10:04 AM
82camaro's Avatar
Car: 82 camaro SC
The pitman arm has nothing on it that can wear. It's considered a 'no wear' part. The steering box can be adjusted, just don't tighten it too tight.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 26, 2001 | 11:28 AM
That's what I was thinking. I did tighten the gear box a little bit, but it didn't seem to help. I guess some day I'll have to fork over the bucks for a new gear box.
Old Jul 26, 2001 | 03:18 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
As long as you have threads showing on that adjusting bolt on the steering box you still have adjustment. I don't know the proper method for adjusting it. I had the alignment shop adjust mine. Made HUGE difference. You may have adjusted the wrong way or not enough to notice.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jul 26, 2001 | 07:30 PM
alright, I'll play with it some more, thanks for the help.
-matt
Old Jul 26, 2001 | 08:29 PM
nicmike85's Avatar
Don't play with it to much or you will end up replacing it. Been there done that. I saw an article on a another site that tells the proper way to adjust it. I'll see if I can find it.
Old Jul 26, 2001 | 09:12 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
How old are your wheel bearings? When those get old they can cause "play" in your steering.
Old Jul 27, 2001 | 02:30 AM
Jza's Avatar
Jza
So can the rubber isolator at the end of the steering shaft. When that thing gets flimsy, you get some play before the steering kicks in, even if everything in the suspension is tight.
Old Jul 27, 2001 | 07:38 AM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
<font face="Verdana, Arial" size="2">Originally posted by nicmike85:
Don't play with it to much or you will end up replacing it. Been there done that. I saw an article on a another site that tells the proper way to adjust it. I'll see if I can find it.</font>
Is this the one you're thinking of?
http://www.monte-list.nu/tech/boxmesh.shtml
(www.montecarloss.com)
Norm
1979 Malibu w/some cornering tweaks and a few other interesting things
Old Jul 27, 2001 | 08:00 AM
<font face="Verdana, Arial" size="2">Originally posted by CaliCamaroRS:
How old are your wheel bearings? When those get old they can cause "play" in your steering. </font>
The bearings are new, I replaced them when I bought the car in march...I was hoping that that would fix the steering. It did help a lot, but it didn't fix it.
Old Jul 27, 2001 | 08:01 AM
<font face="Verdana, Arial" size="2">Originally posted by Norm Peterson:
Norm
</font>
That is basically what I did, except I didn't jack the car up. What significance would that have?
ZMWojnar
Brakes
May 12, 2019 10:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
LT1Formula
Nov 16, 2015 01:13 PM
