Subframe Connector Question
Old Jul 27, 2001 | 07:38 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
<font color = "Blue">I know I should get one before I do any damage to the car. Anyone have any good recomendations on which one to get. Perferably one that's not too expensive.
Let me know Thanks. Kj</font>
[This message has been edited by Kj Rockz (edited July 27, 2001).]
Old Jul 28, 2001 | 09:39 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
yes go with the Spohn SFC's. I am ordering them soon. They are the best design I have seen and the best priced as well. They run along the rocker panela then have additional bracing that connects to the tranny area. all this for $155. If you want them in red or black then it is another $44. www.spohn.net
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
SLP headers, completely done over suspension, black paint with flames, NEW PLAN IN THE MAKING:
BUILD A WILD CHEVY 302 JUST LIKE THE ORIGINAL Z28 HAD
Old Jul 28, 2001 | 09:56 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Spohn, I luv mine!
Also get the Rear LCA's and install them AFTER the SFC's rae welded in. The stock rubber bushings then to melt/burn during welding.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 29, 2001 | 09:26 PM
812MANY's Avatar
You melted the bushings? what kind of welder are you using??!!
I just made my own on Saturday. 1"X2"X.110" CR1018. 2 pieces 63" long. Cost me less than $50.
I ran them along the pinch weld, from 1/2" infront of the rear LCA mounting bolt up to the edge of the front wheelwell. We stitch welded it to the body with 6" beads 4" apart, then hammered the pinch weld over (less then 1/8") next to the box steel and welded on the opposite side from the body welds, we also welded the front and rear all the way around, and put a piece of box steel between the other side of the LCA mount and the rear subframe.
Only took me 4 hours from the time the car hit the lift to the time I was gettin' sideways on the 1-2 shift
Whatever kind you get, make sure you pull the seats and carpet up, and have someone sitting in the car with a fire extingusher!
I pulled the carpet up and noticed that the paint on the topside caught fire everywhere my buddy was welding. It was wierd, he'd start and it would burn, as soon as he stopped it would go out.
My car is a T-Top car with a 350/350 and it squeaked and rattled like a *****. Now its as quiet as my dad's '96 coup.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
