Has anyone installed a roll cage ?
Old Aug 19, 2001 | 11:26 AM
b9radz's Avatar
I'm settin' up a 86 iroc for casual roadrace work and i was wondering if anyone has installed a roll cage in there car ? I can do the welding, but was wondering if a cage is available specificly for our cars. Who? How much ?
Thanks, Brad
p.s. the signature is my son's car
My sons car: 86 Iroc,388ci,Brodix,Victor jr,TPI-700r4,3:73.
Old Aug 19, 2001 | 01:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Chassis Engineering sells a roll cage kit for third gens. So doeas S&W race cars. 10 point cage kits start at around $200.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 20, 2001 | 03:25 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
I wouldn't bother with a kit if It were me. If you can weld and fabricate, you'll get a much better product if you custom build your own cage. The kits that I have seen for camaros don't include halo bars. they're basically a roll bar with some downtubes tacked on and no real "engineering" put into them.
my .02
Clem
SCCA TransAm Series Race Mechanic/CrewChief
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, NO T-tops, (unfortunately) Auto Transmission (hopefully not for long)
Old Aug 20, 2001 | 07:13 PM
87tpi420's Avatar
i agree they are just a basic hoop and a bunch of straight tubing. i plan on doing one in my car too but dont know how yet so i would like to know what other people plan on doing or have done. i plan on a stainless steel cage. custom bent at a fab shop to go right along the roof so it doesnt stick down. and a low door bar so as i dont have to climb over it.i will cut/notch and weld it myself just need it bent to the roof contours. but i also want to put a five point harness in and i dont know how i am going to put the shoulder straps in and still utilize the rear seats if a want passengers. any ideas people?? i was thinking a removeable crossbar that the shoulder straps would go on.
maybe a center bar going vertical on the tranny tunnel for one shoulder strap and the other on the main hoop? /|-|-|\ look like that kinda?
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Aug 20, 2001 | 11:30 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Have you ever looked at the gorilla cage for the ricers? It totally boxes in the rear of the car, yet leaves room for the rear passengers, what it does basically is creates a square around the rear seats, with bars above the passengers, below, in back and in front of them with mounting surfaces for 5 pt harnesses for the front seats if they are needed. If i have the skill/knowledge/equipment to do a cage for myself in the future, ill most likely design something similar to this as i would still like to have those rear seats if possible, and also tie the cage into the subframe.
Slowly getting slower 1989 Firebird.. modded heavily for a v6
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
Old Aug 21, 2001 | 08:38 AM
ATOMonkey's Avatar
You can bolt the harnesses to the floor and run them up the back of the seat, or my favorite inside the seat. Just make very sure that you use good washers and that the floor boards are in really good shape, because if you ever need them(hopefully that never happens) you don't want the harness pulling through the floor.
Old Aug 21, 2001 | 08:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Trouble with mounting the harnesses like that is that it will never pass a tech inspection.
You could make a mini roll bar. Instead of the main hoop going right across the car it just goes behind the driver then back down to the floor. The back bar then only goes behind the driver. Entry to the rear still wouldn't be possible on the driver side but there wouldn't be any obstruction on the passenger side. The forward and rear down tubes would still cause slight problems.
Old Aug 21, 2001 | 08:50 PM
WOODY MCC's Avatar
I have seen a swing out forward down tube but I can't remember what company .I also want to install a roll cage of some sorts, but as to not ruin my no option 87 GTA . Maby a hoop and two rear down tubes or sumthin uhhhhhh I well errr maby hmmmm ahh .I hate to spoil the car but I should think of saving my own @ss incase I pull a turtle some day !!!!
_________#3 lives on in #8 have a BUD and live life__________
[This message has been edited by WOODY MCC (edited August 21, 2001).]
Old Aug 22, 2001 | 12:06 AM
Jza's Avatar
Jza
<font face="Verdana, Arial" size="2">Originally posted by Graeme'sFirebird:
</font>
I don't know if we're thinking about the same cage, but the one that I looked at once, called "monkey bars" had fine print that said (not intended as a safety cage, for cosmetic use only).
Old Aug 22, 2001 | 02:04 AM
i dont think so.. this one was clearly listed for drag racing associated driving.
1989 Firebird. Modded.
-For Sale-
Email: gglasgow@socal.rr.com
asking price: 3300 with a new paint job. Email for specs
#3 Forever
My Site:
Old Aug 22, 2001 | 02:24 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Monkey bars, for show looks only.
Yes, my fastest race car is now a Honda.
FOR NOW!
BTW check out the CompCams/ZEX add.
Why they call me "Slim" I'll never know!
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Aug 22, 2001 | 08:44 AM
ATOMonkey's Avatar
That's damn good. What did you do to get that Honda down into the 13's? My friend and I are working on a new 4-link rear to get front drive cars better 60 ft times and do our best to keep them streetable witout breaking axles and CV's. Keep up the good work.
Old Aug 22, 2001 | 04:48 PM
88Vette's Avatar
Kenny Brown makes a roll cage for 3rd & 4th gen. They look pretty slick, I saw an install of one on Horsepower TV. Doesn't restrict access at all for front/back, bolts in and works great.. Also operation thunderchicken in GMHTP uses it and they do nothing but praise it.
Old Aug 23, 2001 | 12:57 AM
Omar's Avatar
They did an intall on Horsepower TV? When?!?!? I am pissed that I missed it.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 24, 2001 | 06:18 PM
DM91RS's Avatar
Car: 91 RS
Installed a 6 point roll bar with diagonal and seat back brace in both of the ones that I have owned. They work! I spun and flipped my previous RS and landed on the side rolling on to the roof. My only injury was a scratch on one knee from the T-top glass when I released my harness and climbed out! Also helps alot with chassis stiffening . The car had the side bars connected to the front and rear of the frame connectors. Every sheet metal part on the car was totaled except the drivers door and it still opened and closed like new.
91 RS L31 350..... Vortec heads..... Holley 670..... Edel. intake .... Lt4 cam 1.6 rollers ..... Edel. TES headers .. 3" exhaust ..... 5spd 3.08
Vintageracer
Jan 10, 2020 05:33 PM
crazynights
Aug 21, 2015 06:53 AM
IROCZ1989
Aug 19, 2015 08:15 AM
z28addict8490
Aug 7, 2015 08:48 PM
