factory sway bar size?
Old Nov 19, 2010 | 07:25 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Can anyone tell me what the factory size sway bars were for an 86 camaro sports coupe? im looking at getting a 36 mm front sway bar off of an iroc then im looking at getting a 34 mm rear sway bar.
Old Nov 20, 2010 | 01:53 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: factory sway bar size?
There's a spec site somewhere that may tell you what was standard. Do you mean 24mm on the rear not 34mm?
Old Nov 20, 2010 | 06:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some Camaros 89-92 were equipped with the hollow 36mm/solid 24mm combo. Some 'Birds 86-92 were equipped with the above.
JamesC
Old Nov 20, 2010 | 09:25 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you probably have a 32 front bar, but its really quite easy to measure it to be sure.
Old Nov 20, 2010 | 09:48 AM
Engine: L31 350
mind asking how i measure? do i just go around the sway bar? and no i mean 34 mm rear sway bar.
Old Nov 20, 2010 | 09:52 AM
JamesC's Avatar
Stick an adjustable wrench around it and measure the distance between the jaws.
There is no OE 34 mm rear bar.
JamesC
Old Nov 20, 2010 | 12:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
JamesC
or a cheap set of calipers works too. Just be sure to measure the bar away from any bends, since the steel is slight distorted there and the measurement will be off.
and yeah, no rear 34mm bar, largerst is a 24mm. If you do aftermarket you can find some big rear bars, but they are made to help the rear of the car squat evenly when launching at the drag strip. On the street, it would be a bad idea and make the rear of the car terribly loose in turns, if you are not careful, you will end up spinning out or wrecking
oh, and be sure to grab the sway bar mounts and bushings from the other car too, as i hear the mounts are different sizes for the smaller/larger sized front bars
Old Nov 20, 2010 | 12:57 PM
JamesC's Avatar
I believe the mounts/brackets are the same for all cars; only the bushing size changes (for example I used the same brackets from my 34 mm front bar when I swapped in a 36 mm bar. I used both GM 36 mm 1LE bushings and the TDS version). TDS sells a kit with brackets and your choice of bushings.
http://www.top-downsolutions.com/pro...products_id=42
JamesC
Old Nov 20, 2010 | 01:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
JamesC
like i said, im unsure, but i thought heard somewhere they are different.
thanks for the link, i forgot that Lon still owes me a set of 36mm bushings.
Old Nov 20, 2010 | 01:29 PM
Stephen's Avatar
Car: 87 GTA
.....and yeah, no rear 34mm bar, largerst is a 24mm. If you do aftermarket you can find some big rear bars, but they are made to help the rear of the car squat evenly when launching at the drag strip. On the street, it would be a bad idea and make the rear of the car terribly loose in turns, if you are not careful, you will end up spinning out or wrecking.....
Old Sep 3, 2013 | 10:14 AM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
This was helpful. ..ty everybody from the not so distant past I hope everyone has been keeping it shiny side up.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
