Guys I am going to buy new sway bars, please list the 3 best 1 to get.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I want to buy front and back, please list the best 3 to get in order and also list a good budget set. If you could tell me where I can get them and maybe a link. Prices are help full. The car is lowerd and the rest of my mods are below (please read). Since the car is lowerd do I have to modife the endlinks? Thanks alot P.S I realy want the car to handle like it is on rails.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Get the 1LE sway bars,36mm front and 24mm rear. You can get them at www.spohn.net or your local dealership can get them for you.
Car: 86 Z28
What about after market? hotckins and herb adams? What about adjustable ones?
Car: 86 Z28
I haven't heard anything about aftermarket ones, but I love my IROC ones. they're stock and they're awesome. I put new hardware and bushings from PST, and with the other mods my car handles awesome!
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
Car: 86 Z28
Are the 1le bars the same as the ws6 ones?
Axle/Gears: 3.45, 3.27, 3.27
1LE and WS6 are the same. I agree on picking them up used from a junkyard. I bought new 1LE sway bar links though. Of course new sway bar bushings, either poly graphite or stock rubber, depending on the handling and feel you are looking for. I drilled the front sway bar bushing brackets and installed zerk fittings so I can grease them with synthetic grease at oil change time. I drilled a hole in the bushing where it aligned with the zerk fitting. Then I took a Dremel and cut circumferential grooves and an X groove in the inside of the bushings for the grease to flow. The ES rears came with grease fittings.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
90 RS Convertible
(626)369-0040
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
It'll be hard to find bars stiffer/more effective than the factory 1LE or WS6 bars.
If you must go aftermarket, I've had really good experience with the Herb Adams bars.He used to be an Engineer at GM and he has a lot of experience with third gen F-bodies.The end-links on his bars are the heim-joint all-steel type!
-Rich-
-Rich-
Car: 86 Z28
Yeah I want the herb adams ones but they will end up cost close to 6 hundred bucks to buy all said and done. If any ones know where to get them cheaper or a good spot to pick up the 1 le bars it would be helpful. Thanks
USED...IROC, WS6...doubt you will find a 1le of b4c but there ya go. I am not sure but I think the the owner before took out the IROC 36mm and put in a 32 mm one...he even said that it was a super heavy duty one....are the 36 hollow and maybe mine a 32 mm solid? I dunno, but with the lowerd car and this superhard swaybar (with poly bushings) and the stock rear my car has NO body roll...stiff as a board.....very hard ride too.....gotta try and find away around that.....
[This message has been edited by camaro6spd (edited November 19, 2001).]
have you contacted james c he usually has themlook in the classifieds if he doesn't have a set listed use one of the other ads to contact him
When you are content to be simply yourself and don’t compare or compete, you will be respected
I am surprised I thought I saw one on there just the other day. He doesn't have any coming up? I can't think of any place else. James c is where I got mine from. Unless tgr has one.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
