bad brakes?
Old Nov 27, 2001 | 07:52 PM
britered86transam's Avatar
bad brakes?
there is alot of play in my brkae pedal latley, and sometimes when i brake the E brake light comes on, its been doing thsi more frequently latly. could this mean my brakes are dead or i jsut need new brake pads? 86 trans am
[This message has been edited by britered86transam (edited November 27, 2001).]
Old Nov 27, 2001 | 09:51 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
try bleeding the brakes, the lines can get air in the system and we all know that air can be compressed. When your pedal goes to the floor, you're just compressing air, not stopping the car. Check the pads too but worn pads should not cause excessive pedal travel.
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050" w/108 LSA
Triumph Spitfire SCCA roadracer. 1.1 liter 4cyl w/ 14:1 comp.
turns on rails!
Old Nov 28, 2001 | 08:08 PM
how do i bleed the brakes, i have never had to do that before
Old Nov 28, 2001 | 10:52 PM
Tom84L69's Avatar
Car: 84 Z28
You need two people to do this. One person in the car to pump the brakes.
You will also need a bleeder can to catch fluid. It's basically a plastic can with a clear tube(auto parts store).
The other person goes to each wheel with a wrench to loosen the bleeder valve on the calipers. Open the valve and say "down" have the guy in the car tell you when his foot hits the floor by saying "down". Do this two or three times and look for air bubbles coming out throught the tube.(warning! keep an eye on the master cylinder and do NOT run it dry! refill as necessary)
Tell the driver "down" and try to catch him mid pump by tightening the valve. If you miss, just do it again. Verify with the driver that you caught him. Do this to all four corners.
My dad and I do this between every race on our race car, the brakes get so hot that they boil the fluid, creating air in the system.
say "down" and "up" both of you, it makes it less likely for messing up.
turns on rails!
Old Nov 28, 2001 | 11:33 PM
Tom84L69's Avatar
Car: 84 Z28
WHOA!! WAIT i forgot 1 thing. Be sure that the driver does not let the brake pedal up EVER unless all valves on the calipers are closed. If any one is open, the system will suck more air in and heighten your problem.
Sorry bout that and it just goes to show that you shouldn't take everything you read here as Bible. It may be wiser for you to take the car to a brake shop, I'm sure it wouldn't cost too much.
Old Nov 29, 2001 | 12:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I've got this same problem, and so does eightTfourTA, and we don't have any air in our system. See this message: https://www.thirdgen.org/messgboard/...ML/003407.html
It's quite interesting that you have this problem, briterd86, and you haven't touched your brake system at all. I converted to rear discs (and had to change my master cylinder), and am having this problem; especially with the BRAKE warning light. I think it might be our rear calipers... as written in my message.
Oh- that's not an E-brake light when the E-brake is down- it's a "unequal fluid pressure" warning light! That means that your front brakes and rear brakes aren't receiving equal pressure... and it warns you to get it fixed quick!
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 30, 2001 | 08:13 AM
VampireHunterC's Avatar
Also when bleeding the brakes, it is best to begin with the brake farthest from the mater cylinder, and proceed closer.
Old Nov 30, 2001 | 11:38 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
On some other cars I owned at one point the brake light comes simply because of low fluid level.
Don't know if this rule applies to 3-gens though.
ORIGINAL OWNER
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Partial TBI mods, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Spectre valve covers and accessories, Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: the rest of the TBI mods & Suspension upgrades
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
