15x10 w/ 5-1/2" backspacing fit rear?
Old Dec 3, 2001 | 08:18 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
...on my '91 Z28 w/ Discs? I've found a good deal on a pair of Weld Draglites & want to run 275/50/15's? Any feedback greatly appreciated!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
Old Dec 3, 2001 | 08:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They'll fit the older rear disk brakes. I don't know about the larger rotors and PBR calipers.
My rims are within 1/2" of the park brake cable bracket.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 3, 2001 | 08:33 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
Will this be the case w/ all 15" rims or just that wide?...should I stick w/ a 15 x 8 or go the 16 x 8?
Old Dec 3, 2001 | 09:32 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
Would the wheels above fit under the car or stick out partially?
Old Dec 3, 2001 | 10:14 PM
AlkyIROC's Avatar
Car: 87 IROC L98
<font face="Verdana, Arial" size="2">Originally posted by Ed1LE:
Will this be the case w/ all 15" rims or just that wide?...should I stick w/ a 15 x 8 or go the 16 x 8?</font>
Depends on the backspacing.
<font face="Verdana, Arial" size="2">Originally posted by ryn28:
Would the wheels above fit under the car or stick out partially?</font>
The rims fit fine but will depend on the tire size on if they'll stick out or not. My 28x9 slicks fit under the fenders. The 9" is the tread width not the tire section.
Old Dec 4, 2001 | 12:37 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I asked this question last week (do a search) and found that yes 15" rims will fit over the stock 89-92 rear discs. But I also found out that there arent any 15x10" rims that will fit correctly in the wheel well, unless you get them custom made. 15x8" is the largest generic wheel made that will fit.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Southern California
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 4, 2001 | 04:59 PM
SteveSpohn's Avatar
I run 15x10 with 5.5" backspacing, fit no problem.
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Dec 4, 2001 | 11:57 PM
AZ88Maro's Avatar
Steve what size tire do you run, 275/50-15?
Old Dec 5, 2001 | 12:02 AM
SteveSpohn's Avatar
28 x 11.5 x 15 ET Streets
Old Dec 5, 2001 | 04:15 PM
AZ88Maro's Avatar
So 11.5 thats what 315mm about?
C409
Dec 17, 2016 09:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
SnkSknrZ28
Nov 25, 2004 11:00 AM
SnkSknrZ28
Nov 25, 2004 12:26 AM
Tailmaphas
Apr 16, 2003 10:29 PM
