anyone know why my car hops when making turns like im running a flat???
Old Jan 15, 2011 | 07:56 AM
CHJ37's Avatar
Car: 1991 Chevy Camaro
Engine: Chevy 305 bored .30 over
when i make turns, usually right turns, my car kind of hops like im running on a flat tire. not sure if its a bad bearing or bushing. any help would be great. thanks guys.
Old Jan 15, 2011 | 09:40 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: anyone know why my car hops when making turns like im running a flat???
if this is at speed, you need an alignment. If its at slow speeds, like in a parking lot, thats what these cars do. Its a problem with the factory front end geometry, its normal, but again, it can get much worse if your alignment is out
Old Jan 15, 2011 | 10:36 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
My car does this when backing out of a parking lot - It feels like its dragging a front tire when I'm backing out with the wheel turned. Strange.
Old Jan 15, 2011 | 11:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Regularly turning lock to lock might not be the best idea given the steering box issue (cracking/tearing). If you haven't installed a steering box brace (aka Wonderbar), you might consider an install.
JamesC
Old Jan 15, 2011 | 11:56 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Front wheels or back?
steering box crack, or one of your sway bars has detached
Old Jan 15, 2011 | 12:42 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I think its a factory problem. But I noticed after I rebuilt my front suspension (i did everything) and got a custom alignment. It was greatly reduced/nonexistent.
Old Jan 15, 2011 | 02:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The problem is you can turn the wheels to far at low speed, same can be done with your bicycle, turn it to far and try and pedal, it wants to go straight, not turn.
Old Jan 17, 2011 | 08:06 PM
CHJ37's Avatar
Front wheels. And thanks for all possible problems guys. Helps a lot.
Old Jan 17, 2011 | 11:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Did you replace the center link and was it installed rightside up? Flipping the center link over can be done. I have mine flipped over so that I could lower the engine more however it really screws up the steering geometry. I never have to worry about corners or sharp turns so it doesn't bother me. I did however have to install some different steering stops. The angles allowed me to turn sharper than the linkage should allow and the wheels could overcenter on the linkage.
Old Feb 23, 2011 | 08:46 PM
CHJ37's Avatar
JamesC
So essentially a wonderbar (steering brace) would fix the problem for me? or reduce it?
Old Feb 24, 2011 | 07:04 AM
JamesC's Avatar
The Wonderbar would prevent damage to the steering box area, but wouldn't prevent skipping.
JamesC
Old Feb 24, 2011 | 07:22 AM
58mark's Avatar
I had a problem on my car where occationally the front end would bounce when coming to a stop. I know I probably have a crack somewhere in there, but after installing the wonderbar, It hasn't happened since.
Old Feb 24, 2011 | 07:34 AM
JamesC's Avatar
In another thread, the consensus was that if an owner felt a 'day and night' difference after the Wonderbar install, it was probably because there was previous damage to the area. I buy that idea because most people, if the car is in tip top condition, wouldn't be able to tell if a Wonderbar had been swapped in or not.
Here's a link to the thread I mention, should anyone be interested:
https://www.thirdgen.org/forums/susp...questions.html
JamesC
Old Mar 8, 2011 | 09:56 AM
CHJ37's Avatar
steering brace fixed it. thanks again guys.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
IroczFan
Oct 6, 2015 10:13 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
