Alignment Settings?
Old Jan 29, 2011 | 07:57 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Alignment Settings?
I am going to be getting my car aligned this week after doing a c5 and ls1 brake swap and some other suspension work. What are some good settings to have the car aligned to? The car is an 85 Iroc with suspension mods in my sig.
Old Jan 29, 2011 | 08:00 AM
Doug Phillips's Avatar
Car: 85 IROC race car
Engine: 425/435 rwhp/tq
Transmission: WCT5 .80 5th gear
Axle/Gears: 3:42
Re: Alignment Settings?
Setting will depend on what you plan to do with the car. Street, drag, lapping, road race, combo?
Old Jan 29, 2011 | 04:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The car is mostly street driven.
Old Jan 30, 2011 | 10:16 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How would these settings seem?
Caster L (+4) R (+4.5) Camber L (-0.5) R (-0.5) Toe (3/32)
or would this be better?
Caster L (+5) R (+5.5) Camber L (-1) R (-1) Toe (3/32)
Like I said, the car is mostly street driven. How would tire wear be with these settings?
Old Jan 31, 2011 | 11:24 AM
Guest
Guest
Posts: n/a
I don;t even know what tires rand and size you are running. For very good 245-50-16's I would recommend 5/5.5 caster- -.7 to -.8 range on camber and 3/32 toe in with soild strut mount bearings. Crappy stock strut mounts I would use a little higher camber and a little lower caster.
Old Jan 31, 2011 | 05:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am running BF Goodrich G-Force tires (245/50-16 may upgrade to 255/50-16's) and I just installed a set of UMI caster & camber plates the other day. Which of the settings would you recomend Vetruck?
Old Feb 1, 2011 | 10:53 AM
Guest
Guest
Posts: n/a
I hate those tires. Those were the last tires I put on my Camaro before it went to the ex. They get real squirmish above 88 mph like as if centrifical force fails the integrity of the sidewalls. (Yeah, I know everyone, 88mph was the speed of the Delorean in Back to the future- Ive heard the joke already).
If you drive the car hard all the time, then go up to -1* on the camber. Otherwise if it sees lots of freeway miles then leave it in the -0.7 to -0.8 range (basically shoot for -0.75)
Old Feb 1, 2011 | 06:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How much difference would there be between -.7 to -1 on the camber? Reason I ask is because I don't drive hard all the time and I don't do a lot of highway driving either.
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
skip91
Sep 24, 2015 03:29 PM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
