91 CAMARO WITH 468 BBC
i just got finished dropping a 468 in my 91 camaro it should be running roughly 450hp or more to the wheels. im trying to decide on rear suspension. i would lik to run a 10.5 tire. i current have 373 gear blah blah blah but im looking for good ways to make it hook. good if at all possible cheap ways to make it hook and go. any help woud be greatly appreciated.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: 91 CAMARO WITH 468 BBC
We will need more specific information then that. Like what is your current suspension and rear differential?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if your current rear is a 10 bolt, once you get it to hook, it will be toast.
but yeah, we need to know more about your current setup
ok sorry.... i bought the car from the guy that built the motor for me and accorrding to him it will hold up....we will see about that..... 373 rear gears compleatly stock suspension. trying to get an idea in what direction to go from people that have been there done that so i dont waste money on something that does not work. turbo 350trans has been gone through( 2800 stall) should have plenty of low end i the car.
Car: 1991 RS
Engine: 5.0
You have stock suspension so it would seem like an easy bet that you should upgrade it. Do you want to stay with stock style? Four link? Back half? Plenty of info to look at just need to search around.
ok now i know not enough info again. bare with me........ would like to run a10-10.5 tire. dont really want to go crazy. dont want to backhalf nor 4 link the thing. guess if i need to i need to but would like to use torque arms etc. to try and keep it semi cheap
Car: '89 GTA
Engine: 5.7L LS1
Well just based on what vague information you have given I would say minimum would probably be LCA's, SFC's, and a poly torque arm bushing. I'm not sure if you would need offset lower rear control arms to run a 10.5 tire.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To run a 10 or 10.5" tire, you'll probably have to do some inner sheet metal modifications to get them to fit. Staying with a 26" tall tire will reduce how much needs to be done but a taller tire like 28" is much better to use.
Don't expect the tiny 7-5/8" diff to last very long. It depends on how good the tires can get traction. All the upgrades you can do to the diff still won't fix the fact that it has a ting ring and pinion and tiny teeth on the gears. These will break before anything else.
The most common diff upgrades is a Dana 60, 12 bolt or 9". All are available as direct bolt ins. Don't expect to find anything in the junkyard that can be an easy swap to make it better. Upgrade the LCA, torque arm and panhard bar to better aftermarket components. Install some sub frame connectors and if required, relocation brackets.
Having a high HP engine with lots of torque means nothing if you can't get the power to the ground. It's a package deal. A better engine means the entire driveline also needs to be upgraded to handle the extra power.
There are always ways to make a third gen hook but very few if any are considered "cheap"
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
to the wheels? I wouldn't get rid of that. Why would you suggest that even? And let's not forget he's making a substancial amount of torque with that 468. Don't know why you'de suggest that.
If you want to plant it, you're going to spend some money doing it. If it were me I'd start saving for a new rear and do other supporting modifications around it once you've got it pulled out.
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
any well built engine should make atleast 1hp per cube to the tires. 450hp to the tires is nothing a well built sbc should make.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Why fix something that isn't broken? HP is worthless if all you do is spin your tires (or break your rear). He'd be better off putting the cash into his suspension, not a new motor taking two steps backward on a smaller cubes from scratch.
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
or do it right the first time. he could run the 10 bolt. as long it doesnt hook hes fine.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Will you give me advice on how to get my 283 to make 450 to the wheels in my Camero? It's got dome pistons, 3/4 cam, roller tip rockers and a high rise intake. I think some nawws might help it out too. I want it to leave like the picture in my sig. God I love that car............
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You would say something like that. Supreme Member
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Car: 1982 Camaro
Engine: 555 BBC
BTW my 10.70@126 406 engine didn't make 450 to the wheels either. It must not have been well built.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You said a well built sbc can make 450 to the wheels.. I have a well built sbc (283) and I can't seem to get that out of it so I was asking for advice. You are the one who generalized the statement. So what should I expect?
Oh, and I hear once you hit 450 to the wheels you get a golden ticket kind of like the one from ***** Wonka, except it's from TGO to you expressing their love for such a faithful member.
