Moog 5665 question
Car: Trans Am GTA
Moog 5665 question
Ok so I have some air shocks on now and I am wanting to get some moog 5665 springs...If I replaced the springs, does that mean I would get additional lift from the springs?
(In simpler terms...Will the springs reduce the travel in my air shocks?)
Re: Moog 5665 question
Generally, yes. But the only way to keep the air shocks from breaking your car, is to take them off and put REAL ones on it.
You must not have had the air shocks for very long; only a couple hundred miles? Or maybe they aren't working? (leaky air lines?) Otherwise you'd be asking some different questions.
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
You don't need airshocks with the 5665s, they will raise the rear 3inches over saggy stock springs and plants that rear on hard launches never hitting the bumpstops
However it will be one stiff *** ride. Senior Member
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
If you put brand new rear springs on with brand new air shocks you will hate it. It will 'bottom up' more then it with bottom out, Did this to a customers car per his instructions and he said it rode awful, it was insanely stiff and the rear suspension could hardly cycle an inch. Senior Member
Car: 1989 SS
If you put brand new rear springs on with brand new air shocks you will hate it. It will 'bottom up' more then it with bottom out, Did this to a customers car per his instructions and he said it rode awful, it was insanely stiff and the rear suspension could hardly cycle an inch.Senior Member
Car: '89 GTA
Engine: 5.7L LS1
Car: 1989 SS
TA8487
Aug 11, 2015 09:02 PM
way to many beers.
