question on subframe connectors
Old Apr 10, 2011 | 08:35 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
i just got my jegs bolt in connectors. my question is, 1 bar is perfectly straight and the other bar has 2 bends in it. should it be bent? and it appears it is the pass side 1?tia
Old Apr 10, 2011 | 09:18 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: question on subframe connectors
Yes, the passenger side needs clearance for the exhaust & cat. Also make sure you weld those bolt on SFC's sooner then later.
Old Apr 10, 2011 | 10:40 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
thanks DJ. anyone have pics of these mounted?
Old Apr 10, 2011 | 11:51 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
What he said, they are almost always different for left/right side of car, also do not bolt them in, weld them in, the problem with bolting them in is that you're bolting them into sheet metal, the bolts can eventually start to tear into the metal.
Old Apr 10, 2011 | 11:59 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
buddy of mine runs a nova with bolt ins and runs 9's and it leaves on the bumper he has no problems
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
since i got no instructions, where exactly do these bolt to?
Old Apr 10, 2011 | 12:43 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Pics of installed SFC's:
http://www.umiperformance.com/catalo...roducts_id=127
http://www.spohn.net/shop/1982-1992-...-Top-Cars.html
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
