Raising the rear.
Old Apr 12, 2011 | 09:14 AM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Raising the rear.
I've been reading up on raising the rear end and I was debating using the rubber stoppers that go in the springs. Is this a good/safe way to raise the back?
Old Apr 12, 2011 | 09:35 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Raising the rear.
No. They are just a band-aide for worn out springs they should be replaced to begin with.
Old Apr 12, 2011 | 09:47 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Why do you want to raise it?
Old Apr 12, 2011 | 12:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Use metal spring spacers - they go in under the spring, come in many different thicknesses.
Old Apr 12, 2011 | 12:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or throw in a fourthgen isolator, which will jack the rear up an inch or so.
JamesC
Old Apr 12, 2011 | 02:29 PM
I like the look of a higher rear and lower front. Are the isolators easy to install? As far as the metal spring spacers, do I have to remove the springs to install them?
Old Apr 12, 2011 | 02:35 PM
JamesC's Avatar
Yes. Drop the rear far enough to remove the springs, swap the isolators (using tape to hold them in place), reinstall.
James
Old Apr 12, 2011 | 10:28 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
JamesC
Super easy to swap in. Should raise the rear about an inch.
Old Apr 12, 2011 | 10:50 PM
I was looking to go another 2-3" higher. The isolator idea seems like the cheapest.
Would something like these on e-bay be bad?
http://cgi.ebay.com/ebaymotors/REAR-...item1c1ae661bf
Old Apr 13, 2011 | 02:37 PM
Car: 1992 RS
Engine: Carbed 350
Geez - if just going for the look - before you buy, why don't you jack the rear of the car up one inch, 2 inches, and 3 inches and look. 3 inches seems like alot - in my opinion would look silly. I would think a 1 inch lift would give that little bit of a mean stance that I think you are looking for.
But yes, what you have shown from ebay is the metal spring spacers I was referring to - just as easy of an install as isolators - isolators go on the top of the spring, those spacers go on the bottom of the spring.
Old Apr 13, 2011 | 02:40 PM
Car: 1992 RS
Engine: Carbed 350
This all got me to wondering ... has anyone tried a hockey puck on top of the spring? I don't remember if the top of the spring is too large for a hockey puck. I know we used hockey pucks with holes drilled through them to do a body raise on jeeps and 4X4 trucks back in the day because they were cheap, made of hard rubber (so they flexed a bit and didn't have any metal-to-metal contact), and easy to do. But if memory serves me, the top of a coil spring is too large, the puck would just fall into the spring.
Old Apr 13, 2011 | 03:01 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
The rear of my Firebird is lifted, it was done by a previous owner, and I have no idea how they did it...lift springs? I've been under it and its all spring, no spacers, someone once suggested that they may have used chevy S10 springs, I don't know if they would fit..but I digress...When I park next to other 3rd gens it is plain as day that its lifted, and it looks awsome, but its much easier to scrape the airdam off of large bumps and dips in the road, totally changes the angle of the front end towards the ground and it can be a PITA, just something to think about.
Old Apr 13, 2011 | 04:30 PM
Car: 1992 RS
Engine: Carbed 350
In your case they might have used Jeep springs - I saw a thread here somewhere about someone using springs from a Jeep in their car. Most springs are generally the same size and can swap out alot of times - just different load capacities, different lengths, different compression rates, etc.
Old Apr 13, 2011 | 11:39 PM
Would any of this require a panhard bar? I'm not that familiar with those or what their purpose is.
Old Apr 14, 2011 | 12:24 AM
Car: GTA
The Panhard Bar controls the side to side movement of the axle to keep it centered. There is a good chance your car at stock height, does not have the rear end TRULY centered, but there is room to vary by about a full inch & still not rub.
For the most part, Adjustable PHBs are used for fitting wide tires to prevent rubbing, or for Lowered cars, or even a higher car.
Use the weighted string hanging off the quarter panel method to measure where your rear end is, then decided if you need, or just want, an adjustable one to align it up better.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Vincent135
Sep 28, 2015 10:50 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
