steering/suspension issue
Old Apr 19, 2011 | 05:08 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
i serached and didnt really find an answer so i guess i will just ask...my 91 z28 has an issue...i know the sway bar end links are trashed(replacing them this weekend) but my issue is it pulls hard to one side when i brake..is that characteristic of bad ball joints or will the sway bar end links do the trick?
Old Apr 19, 2011 | 05:12 PM
87Selene's Avatar
Car: 1987 black Firebird Formula
Engine: 5.0 305 TPI
Transmission: 700r4 automatic
Axle/Gears: Stock
Re: steering/suspension issue
That sounds like the brakes on the side that is pulling are bad. But I'm still learning
Old Apr 19, 2011 | 05:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Characteristic of bad brakes - maybe need new pads, new rotors, or have a caliper stuck.
Old Apr 19, 2011 | 05:17 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
gonna agree on brakes. probably a caliper sticking or could be a bad hose. lucky for us, both parts are reallllly cheap at you local part store (always recommend doing both sides too)
Old Apr 19, 2011 | 05:42 PM
Car: 1991 z28
Engine: 305 tpi
do think the brakes need to be done and i will certainly do those asap as im losing braking power and the front end also shakes bad when heavy braking is applied thanks for the input i just wanted to make sure it wasnt a common issue with a major compontent such as balljoins etc. breaks are no biggie done in an afternoon
Old Apr 19, 2011 | 05:52 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Replace the rubber brake hoses first before doing anything else.
Car: 1992 RS
Engine: Carbed 350
Shaking with heavy braking indicates warped rotors. Best to just swap in new ones rather than resurfacing. Make sure you install new rubber brake hoses as well - there's 2 in front and one on driver rear - these can make a huge difference in braking power.
Old Apr 19, 2011 | 06:25 PM
Car: 1991 z28
Engine: 305 tpi
how do i check for bad ball joints i know the car has to be jacked up but im unsure of what to check (idk how to kick the tire so to speak)
Old May 5, 2011 | 09:57 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Jack it up not by a-arm grab tire at 12 + 6 o'clock then pull and push theres and allowed spec for movement but cant recall If its bad youll probly know if the boots ripped its probly bad or on its way out
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
