lowering springs?
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
lowering springs?
Hey everyone I was thinking of dropping my 89 camaro using the eibach kit 1.6" in the front 1.3" rear . My question is can I just install the springs or do I have to get the adjustable panhard rod, torque arms too. what are the positives of using just the spring compared to changing the whole suspension.
Has any one just used the springs ? How do you like it and how does it drive? Does it bottom out ?.
Thanks for all the help
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: lowering springs?
you dont need any of those parts unless you have issues after the install. the axle may be close enough to centered after lowering to not need the panhard, if the pinion angle is still good, no need for the TA.
Good shocks and struts should be installed though.
Engine: 350 carb
Ok awesome. I was looking to get the kyb-gr2 are those any good or should I get something else
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'd have an adjustable panhard bar ready to install. I used the 1" Eibach drop springs, and I needed one - so 1.6 inches is definitely going to need one.
Engine: 350 carb
So how many panhard bar do I need then?
Keep an eye out on ebay and CL- right now in my area there's an adjustable panhard from HP Motorsports for $25.
Engine: 350 carb
Thanks guys for all the help.
So I only need one panhrd bar is it for the front or the rear ? And what side should I install it on ?
I have Eibachs, don't like em, going back to stock. Ride too harsh, or maybe roads suck all over, limits load carrying, rubs tires on harsh bridge aprons. Rears you can put in with no tools just have your heaviest buddy stand on the rear drum with the wheel removed and the old ones slide out and the new ones will slide in but the fronts require spring compressors.
I actually enjoyed the ride of the Eibach springs over my Intrax setup, but like the look and handling of the Intrax more than the Eibach. My Intrax setup is ROUGH. I don't know if better shocks/struts would help my current setup, but the Eibachs had a much sportier feel over stock without being bonejarring like Intrax IMHO. Eibachs weren't low enough ride height.
Since you're new to suspension, perhaps the following link (which is a sticky) will school you a bit with info and pics:
https://www.thirdgen.org/forums/susp...nsion-how.html
JamesC
JamesC
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
I got the pro kit with Kyb's on my car(kinda wish I did go with a different shock but whatever for now). I do not have very many miles on them but it rides really nice. The car only sat MAYBE 1/4-1/2 inch lower than my stock springs and blown out shocks. Also I have an adj. panhard, lower control arms and LCARB's, and the spohn spherical upper strut mounts.
Engine: 350 carb
Thanks for the info, ill be looking in to other shock instead of the kyb's
Engine: 350 carb
JamesC
JamesC
Thanks for the links its great, good info
