Complete overhaul somewhat
Old Sep 20, 2011 | 09:42 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Okay everyone it's coming close to the fall/winter season here in new England an I got big intentions on my 89 Gta trans am I'm looking to replace everything/tighten everything up I plan on dropping the rear sub frame an also the front sub-frame for all new suspension an bushing upgrades I also plan on doing either a tremic 5 speed or even the t56 swap so I wanna get all the info I need to get prepped for the job I know alot of you guys an girls have done it to ur 3rd gen or ur 4th gens so everyone help a fellow f body buddy out thanks in advance
Old Sep 21, 2011 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Complete overhaul somewhat
Originally Posted by soarestransam
I plan on dropping the rear sub frame an also the front sub-frame....
Subframe?
JamesC
Old Sep 21, 2011 | 04:55 PM
Engine: LR4 4.8
Okay I ment the rear end along with the trailing arms torque arm all of it i just don't know On where to start
Old Sep 21, 2011 | 06:27 PM
JamesC's Avatar
You might start with check the stickies at the top of the page.
JamesC
Old Sep 21, 2011 | 07:58 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
The best advice I could give would be to get some good repair manuals, including a factory one from ebay or where ever. Chilton's, even Haynes. You can never have enough information, even from TGO.
Old Sep 21, 2011 | 10:45 PM
Engine: LR4 4.8
Yea I have a least 2 Haynes manuals on the 3rd gen firebird a tpi service manual, I wanna find a actual service manual for 1989 Gta but there prob big bucks an could only be found on eBay or something like that they would help out alot
Old Sep 22, 2011 | 06:12 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I plan on doing the same thing this winter. All new suspension, brakes, bushings and a t56 swap. Good luck man.
What information are you looking for? What is your plan for the car? Whats your budget? We need more information before we can help.
As james said, check the stickies and use the search. I'm sure you will figure out 90% of what you need to know. Then come ask specific questions if you still have some.
Old Sep 22, 2011 | 08:39 PM
Engine: LR4 4.8
well i plan on dropping the front sub frame an pulling the motor an trans out gonna do all new bushings an maybe some new front suspensions lca, sway bar, etc for the rear i plan on putting in new torque arm adjustable one, panhard bar, trailing arms, i would also like to do the termic 5 speed since its cheaper an will still be a good trans for cruising on the highway better then the 700r4 at least also new floor pans an trunk well, also a nice set of weld in sub frame connectors. i wanna do all this in a budget of 3 grand an in a time frame of at least 2 years i think it could be done quicker but ive learned that lesson not to rush a project
Old Sep 22, 2011 | 08:44 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
3k? Sorry, never gonna happen, not for what you have planned.
Old Sep 22, 2011 | 09:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, 3k will go fast
Old Sep 22, 2011 | 09:38 PM
Engine: LR4 4.8
i got pricing on the suspension stuff an all of the stuff that i got from summitracing came to 926.00 thats not after taxes an shipping i will also be able to get some of the stuff off of my race buddies that had 3rd gens for cheap too so i think i might be able to make it work in the 3 grand price range if not ill just do the time frame longer
Bubbajones_ya
Jul 6, 2024 08:32 PM
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
topteam54
Oct 6, 2015 12:21 AM
MORREALE5
Sep 13, 2015 09:01 PM
