What's up with this alignment?
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
Uploaded with ImageShack.us
I highly doubt it's a problem with my perspective, but the car definately pulls hard to the right, resulting in me always holding the steering wheel pointing right.
Firestone always sought to rip money out my ***, claiming my chassis was bent so ridiculously bad that they cannot align it on their computers.
But from an outside point of view, I do notice the passenger tire is sticking out further than the driver side. Is there a way to even this out? I always thought of moving the passenger side strut- if that would make any difference.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: What's up with this alignment?
Thinking about 1 wheel sticking out further than the other.....Any chance you have a Front wheel on the Passenger side & a Rear wheel on the Drivers side?
Engine: 5.0 305 TPI
I'm not sure at all. If anything, the tires are all the same size and brand new.
Whats difference in size of wheels between the front and rear? Is the rear supposed to be wider?
Car: GTA
Both are 8" wide, but the backspacing/offset is different by 16mm.
Once you look at the wheel face & pay attention to them & think about looking for it, you can spot the difference.
The "easier" way is to look at the back of the wheel & they say FRONT or REAR cast into the aluminum, but the visual check of the face should suffice, with no work involved.
Car: 1990 camaro RS
Engine: 305 TBI
the rim stamped rear sits about a half inch in further then the rim stamped front(or the other way around) i dont remember
Car: GTA
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I'm not sure about this, but I would think a rear rim on the front would have clearance issues.
Car: GTA
Your right, it shouldn't work. But judging by the pic, that was all I could come up with. And if you use the factory slip-on spacers, the rear wheels will fit the front making the wheels look like they fit right, with the different dishes, deeper dish on the back. That is how my daughters car is set up.
