post what u did u get traction
Old Nov 22, 2011 | 06:58 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
im haveing troubles gettin traction
Old Nov 22, 2011 | 07:09 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: post what u did u get traction
You really have to give us some more info:
What rear? Tires/size/type? Shocks?
Posi rear and a 245-255 series tire with a quality tire aggressive summer tread should get you hooking up no problem.
Im around 375hp and I have no problems with traction. I run Bilstein shocks all around, 275/45/18 Goodyear f1's, and stock posi unit with 3.73's. I can break them loose If I try but I generally don't have much of a problem with dry weather traction.
Old Nov 22, 2011 | 07:15 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
342 gears tires are 245/50/16 falkens kyb shocks i also have the lower control arm/ relocation brackets ive got it set to the top hole do i need to move it to the lower one just wonderin
Old Nov 22, 2011 | 07:30 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Good tires.
Lower Control Arms [relocation brackets as well but not necessary]
Shocks
Springs
Battery Relocation will take weight off the front and put it in the rear.
Old Nov 22, 2011 | 07:37 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
what r some good rear springs to go with the lca brackets and the 50/50 rear drag shocks
Old Nov 22, 2011 | 07:42 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
ive still got the stock springs whats good to go with
Old Nov 22, 2011 | 07:52 PM
JoeM1986's Avatar
Car: 1986 Camaro Iroc-Z
Edelbrock makes an adjustable torque arm which allows you to adjust pinion angle. If you can get your pinion angle set right it will hook up.
Old Nov 22, 2011 | 08:06 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
i dont have that on there yet ill have to check it out thanks for the info keep comin one any other ideas
Old Nov 22, 2011 | 08:24 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Tubular Energy Suspension, w/ polyspherical bushing LCA's, Poly mounts on trans and sway bar links, UMI torque arm, drag radials (MT's), 3:73 gears, moser axles, auburn posi, w/girdle....
Old Nov 22, 2011 | 08:41 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Drop in a import engine maybe a 1.5, but don't add any stickers it will add to much HP. thought I would lighten up the post
I am currently putting my set up in, 3:42, 4th gen rear with Bilsteins and Founders rear-end set up, I won't know untill it hits the street agin in about 2 months
Old Nov 22, 2011 | 09:16 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
LCARBS
Lakewood 50/50 shocks for the rear
Battery in the truck
Remove the front sway bar
If you dont drive alot, get drag radials(BFG or MT). They wear out quicker than a regular radial but hook up ALOT better
My best 60ft is 1.52
Old Nov 23, 2011 | 01:32 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Konis helped my traction surprisingly with my setup. Et Streets is next for me. Although I see the 9 bolt going soon.
Old Nov 23, 2011 | 06:12 AM
Car: 89 iroc
Engine: 355tpi
what exactly does it do when u take off the front sway bar. also what is a good pinion angle to start off with and what springs r good for just good lanunches
Old Nov 23, 2011 | 08:13 AM
UMI Sales's Avatar
Hey Dusty. The lower hole(s) would be a good thing to try. We have customers who do just fine on the top hole but others require the lower hole setting.
We have adjustable torque arms if you choose to go that route as well.
UMI is having a Thanksgiving thru Cyber Monday sale. Check our site or sign up for the newsletter to see the deals.
For a quick solution, the lower holes should help.
ramey
ps LB9GTA, nice 60 ft!
Old Nov 24, 2011 | 12:31 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
thanks to every one that posted
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Strick1
Sep 6, 2015 02:21 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
