Take an extra 5% Off Founders Performance's already crazy low prices!!
All thirdgen.org members now qualify for an additional 5% off our already super low prices through the end of the year. Please use the below coupon code during checkout to receive the extra 5%. If you have any questions feel free to ask us.
Coupon Code THIRDGEN 5%
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: Take an extra 5% Off Founders Performance's already crazy low prices!!
Great! Love your tubular LCA's abd Panhard bar.
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Awesome! Any chance your driver side panhard brackets will be ready before the end of the year?
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Quick question if i buy the lcas and the relocation brackets do i have to also buy the hardware kit for the lcas??
Hardware comes for the relocation brackets so the axle side will be covered. You can use the factory hardware for the chassis side or you can replace it with new hardware.
Do your LCA relo brackets work on moser axles? What do the weld in ones look like? I don't see pics on your site.
You will need to use the weld in brackets for the Moser. The weld in look the same except for they don't have the bracket that bends 90 degrees to capture the shock mount.
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
Any more of these codes floating around? I noticed they don't honor the old 5% coupon code any longer
Car: 1991 Firebird
Engine: 3.1L V6
SR, most likely not. Prices are already low compared to other companies. What part of Tampa? I need to setup another Tampa or even Florida meet.
yeah. Was just hoping since the original post indicated they provided it for even more of a discount figured it would be worth a shot. Im in Valrico. If memory serves correctly ur in the Plant city area?
Sorry but at our currently low prices we don't have any coupon codes for our own parts. We could put some private ones together for Koni if you're interested.
Car: 1991 Firebird
Engine: 3.1L V6
Yes, Plant City. I will set something up soon. Will let you know.
Thirdgen89GTA
Aug 20, 2015 03:11 PM
1992, 2012, adjustable, bracket, camaro, code, codes, coupon, founders, foundersperformance, good, lca, mounts, performance, work
