A arm, knuckle an spring removal
Old Feb 28, 2012 | 08:28 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I'm taking the following out to get new moog ball joints in is it easier to remove it all at once or should I separate it an remove it that way I already got the sPring compressed an locked down on the a arm so all I should have to do is just remove the two strut bolts an the a arm bolts an I should be alright I think or am I missing something else
Old Feb 29, 2012 | 07:57 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Re: A arm, knuckle an spring removal
The way I have done it in the past is to place a jack under the a-arm and jack it up enough so it just starts to lift the arm. Chain or secure the spring to the arm. Unbolt endlinks, tie rod, strut, pop spindle off ball joint, slowly lower jack to drop a-arm then remove the spring. You can then take out the two bolts at the k-member holding the a-arm and you can get it out.
Old Feb 29, 2012 | 09:53 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I agree.....I chained mine up in case they flew out. Good luck with the arm bolts. I had to use a map gas torch to heat those buggers up even with a good impact wrench
Old Feb 29, 2012 | 08:09 PM
Engine: LR4 4.8
Yea I'm having that problem as we speak I got the nuts off of the bolt now the bolts don't wanna come out of the a arm mounting point I don't have a torch of any kind so I'm just gonna cut the bolts out with my reciprocating saw, an replace them wIth new stainless steel bolts an put a lot of grease when I reinstall it with the new moog springs an ball joints an energy suspension isolators.
TheExaminer
Aug 25, 2015 07:34 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Aug 8, 2015 07:09 PM
