UMI Research & Developement...
Old Mar 5, 2012 | 10:16 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
1. It is true that you are currently working on a Stock Length Upper Pan-Hard Rod Support?
2. If so, what features will it have?
3. How come you don't have any options for the Front Sway Bar?
Old Mar 6, 2012 | 08:28 AM
UMI Sales's Avatar
Re: UMI Research & Developement...
It's true we have the Panhard support on the design list. Unfortunately it's pretty far down. It will be the same construction as our 2024, just with revised geometry. Most likely this will debut in the fall after the busy season.
As luck would have it, we are working on some front bar options as we speak. Sign up for our newsletter to know when they are released.
http://www.umiperformance.com/catalo...page=subscribe
thanks
ramey
Old Mar 6, 2012 | 07:40 PM
1. Any chance of a Three Point Strut Tower Brace from UMI?
2. How about a Strut Tower Brace for Aftermarket Runners/Intakes?
Old Mar 6, 2012 | 08:05 PM
87350IROC's Avatar
Car: 87' IROC
UMI's STB works with AS&M runners, and I would imagine others as well. As long as you don't run the crummy poly motor mounts that raise the engine.
Old Mar 7, 2012 | 07:32 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
3pt Chrome STB would be amazing! It would be the only one other than Edelbrock's as far as I know, and theirs isn't offered in chrome.
Old Mar 7, 2012 | 09:10 PM
UMI Sales's Avatar
Thanks for posting that pic! Sharing information helps all of us. We try as many combos as we can but it's you guys who really test our stuff.
Much appreciated.
ramey
Old Mar 7, 2012 | 10:39 PM
87350IROC's Avatar
Car: 87' IROC
Much appreciated.
ramey
No problem. Let me know if you guys need any other photos.
Old Mar 11, 2012 | 12:30 PM
Will the Pan-Hard Bar Support have the option to be offered in Chrome Moly, like the Pan-Hard Bar and Lower Control Arm's?
I have both in Chrome-Moly. What are the chances of UMI Performance actually listing the weight differences between the two. The web site states "The Chrome Moly construction adds increased strength while reducing product weight."
Old Mar 12, 2012 | 08:15 AM
UMI Sales's Avatar
Hi Six.
There's a great chance we'll be able to publish weights. We started publishing camber curves and intend to share other data.
A CrMo option will be decided during part design. I'm not sure yet if that will be an option.
more soon
ramey
Old Mar 18, 2012 | 04:10 PM
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
I thought the pan-hard support was already being produced, part # 2024?
Old Mar 18, 2012 | 05:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
it is, but its also a relocation setup that also moves the panhard bar itself down, and allows for more exhaust clearance.
Old Mar 18, 2012 | 09:10 PM
UMI Sales's Avatar
86 is right as usual!
http://www.umiperformance.com/catalo...roducts_id=289
The 2024 moves the PS mounting point downward to allow for exhaust clearance.
ramey
Old Mar 18, 2012 | 11:13 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
I can't get the torque arm mount clam to shut all the way it says part # face rear but the mount didn't have a pn on it
Old Mar 19, 2012 | 10:12 AM
UMI Sales's Avatar
Hey sojer.
What part numbers do you have? New stuff or used?
Can you send pics to ramey@umiperformance.com and I can get you fixed up?
thanks
Old Jun 21, 2012 | 11:19 PM
Hi Six.
more soon
ramey
Dear Ramey, any update on publishing the difference in weight between choosing Chromoly VS Mild Steel for certain products? I also think it would be beneficial if customer's could see the weight difference in products offered by UMI (Stock VS UMI)? The Research and Development Department should have these Figures as they relate to the Unsprung Mass of the Suspension Components.
I also recommended Product Number 2024 to a friend, unfortunately he wasn't sold on the idea, He cited that the manufacturer of a product should have photo's/examples relating to the specific use of the product.(A true dual 3" exhaust is hard enough on a Third Gen due to limited space/ground clearance, a photo of 2024 with an actual true dual 3" exhaust would of probably persuaded him)
I always recommended UMI Performance Suspension Components!
Just suggestions, Thank-You for everything!!
P.S. Maybe you can push for that CrMo option on the Stock Length Upper Pan-Hard Rod Support Bar...
Old Jun 22, 2012 | 03:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Much appreciated.
ramey
Hey Ramey will that strut tower brace fit a LS swap car by anychance as I want to get one but dont want to find out when it gets here it doesnt work for me
Old Jun 23, 2012 | 01:10 PM
87350IROC's Avatar
Car: 87' IROC
I don't see why it wouldn't fit. The LS has a much lower intake than the TPI.
Old Jun 23, 2012 | 08:42 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
If it doesn't work, I'll buy it from you.....you know where I live.
Old Jun 23, 2012 | 10:40 PM
6SIX6's Avatar
Car: 89 IROC
LOL oh dont worry if it dont fit ill make it
Old Jun 26, 2012 | 08:08 AM
UMI Sales's Avatar
We've never tried that brace on an LS car. Not sure what to say other than if we get one in here, we'll try it and see. Then post the results.
Old Jun 26, 2012 | 01:23 PM
UMI Sales's Avatar
WRITING IN CAPS BELOW, NOT E-YELLING...
GATHERING WEIGHTS ON COMPONENTS IS TIME CONSUMING AND WE DON'T ALWAYS HAVE THE ORIGINALS AVAILABLE. OUR WEB DESIGNER OF COURSE CAN UPDATE THE SITE WITH WEIGHTS BUT IT'S NOT A FIVE MINUTE PROJECT. I ANTICIPATE BEING ABLE TO DO IT BUT ITS JUST NOT A PRIORITY. IF YOU'D LIKE A WEIGHT, PLEASE CALL OR EMAIL AND WE CAN DISCUSS.
TRUE.
THANKS!
THE PANHARD SUPPORT BAR IS ON THE PROJECT LIST WITH NO PARTICULAR COMPLETION DATE, IT'S JUST UNDER A PLACEHOLDER. IF WE DEVELOP A MILD STEEL VERSION, WE CAN ALSO DO A CRMO VERSION. IT'S JUST NOT READY YET IN EITHER MATERIAL.
Old Sep 11, 2012 | 03:05 PM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
I'm looking at part #2228-b, the body mounted torque arm set up. Is this compatible with the factory torque arm?
Nevermind, I read the details on it, you can probably expect my purchase here soon.
Last edited by firechicken1992; Sep 11, 2012 at 03:07 PM. Reason: answered own question
Old Sep 11, 2012 | 03:23 PM
UMI Sales's Avatar
Awesome on the 2228. I was just checking the info when I saw your edit.
Thanks for considering UMI!
ramey
Old Sep 25, 2012 | 09:03 PM
This thread was originally designed as a R&D request of information and suggestions.
Of the 20+ replies half of them seem to be for other products, questions, suggestions or banter...
Is there anyone else interested in the Stock Length Pan-Hard Support Rod, besides myself?
Old Sep 26, 2012 | 12:01 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am interested. however I know how product development for thirdgens go. I am not holding my breath. One of my winter projects will be to make/weld/powder coat my own out of some steel tubing and thick metal plates. I've heard of members making their own LCAs and SFCs fairly easily in less than a day. Last I looked the bar was fairly straight with one small curve.
Old Sep 26, 2012 | 12:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
What purpose would that part serve? Since the panhard bar itself needs to fit inside the passengerside of the current upper brace, making a tubular part would decrease exhaust clearance greatly. If it was not fully tubular, and had a hollowed section for the panhard to fit in, it would probably get over complicated and cost more money than would be reasonable for a part that accomplishes nothing but add some bling. If you just need the part to look nicer, take the factory piece off, box it where you can if you want too, clean it and paint/powder coat it.
I'm sorry, I just don't see the point in building in that paricular piece.
Old Sep 26, 2012 | 01:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Their price for the relocated version is 200 or so, most likely doing it myself will not cost more than whatever price they use. The price of steel involved wouldn't be much and I can get any flat steel pieces for free. I have no exhaust that runs over the rear to worry about.I'm doing it in the cold months ahead, I won't have much else to do.
Old Sep 26, 2012 | 01:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Apparently, the after market community generally agrees as no makes an OE-type replacement.
JamesC
Old Sep 26, 2012 | 11:17 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
LT1Formula
Oct 8, 2015 08:34 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
