Anyone have an opinion on front end rebuild kits?
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Over the Memorial Day weekend I'd like to rebuild the front end. I'm getting tired of squeaks sloppy steering. I just want to do a rebuild, no need for anything race worthy. I saw this kit (http://www.hawksthirdgenparts.com/ca...ebuildkit.aspx) on Hawks for a reasonable price. Anyone have thoughts on this particular kit? Also I'd like to replace the front struts but I really don't know what good brands are. I've seen prices that range from 70-300 so I'm not sure what the best bang for my buck would be. Thanks for any help!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Anyone have an opinion on front end rebuild kits?
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
The best seems to be Bilstein and Koni at the high end of the price range. You might search KYB AGX and Tokico Illuminas for a more modest price.
JamesC
Engine: 5.7 TPI L98
Car: 91 GTA
Axle/Gears: 3:73
your list looks good. you might want to check your lower ball joints, and sway bar bushings and end links too.
Engine: 5.7 TPI L98
*edit* I actually completely forgot about the sway bar itself. Should I leave this stock and replace the bushings or install a new one while I'm under there?
Car: 91 GTA
Axle/Gears: 3:73
i replace everthing except torque arm and sway bars. ive never had it to a track yet!! so i would suggest to use what you have and just freshin them up with new bushings. this will help keep the cost down or just buy other cool stuff, lol. sfc, coils...
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
go to rockauto.com
check out the price on the same parts..save $100 easy
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
I did full moog on the front of my bird from rockauto and saved some coin, did all steering and ball joints, basically without the kit assembly fee if you will, and shipping is pheonominal from rock auto. Everyone is out to make money, but probably after 30 minutes on slow internet I had everything in one box for cheap shipping. Plus I think right now there is also a 5% discount floating on a Google search.
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
