94 Camaro suspension into an 82 trans am??
Old Jan 7, 2013 | 04:11 PM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
I have a 94 camaro and an 82 trans am sitting in my garage. the camaro doesnt run and i wont have the money to fix both cars. the trans am runs but is in the middle of a resto. i wanted to beef up the suspension in the TA and get new parts for it just to make everything a little newer. I know i do not have the money right now to do that and wont for a while. So the question popped in my head is it possible to put everything from the camaro Z28 with a T-56 into the Trans am excluding the engine? i havent researched anything yet but i know there will be problems before i even get started i just want to know is it possible and if so how much moddification will be needed. i need to look up dimentions on everything and measure everything out yet, just came up with the idea late last night and thought it over with a good friend of mine and previous owner of the Z.
Old Jan 7, 2013 | 04:40 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 94 Camaro suspension into an 82 trans am??
Some of the suspension maybe. LCAs and panhard bar should fit.
I would think the T56 would with bolt in transmember, but aren't they VSS? I would think your 3rd gen is cable driven. So might have issue there.
I was thinking the 700s and factory t56s driveshafts were the same length for driveshafts but the 200c is like the turbo 350 length? Meaning it's a different length than the t56. So you would need to swap the driveshaft over. I would imagine the '82 torque arm would not fit either but the 4th gen one should.
4th Gen rears fit but they are about 2" wider per side, so if you swap that in your 3rd gen wheels will not fit correctly, but you could use the 4th gen rims on the back and then a spacer used on the fronts to get them to fit.
https://www.thirdgen.org/forums/tran...ap-thread.html
http://www.skulte.com/T56.html
https://www.thirdgen.org/ls1reardisc
https://www.thirdgen.org/4thgenrear
Old Jan 8, 2013 | 01:46 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the rear suspension, torque arm, driveshaft, and trans- yes.
the front suspension- no.
you could swap the brakes over, but they wouldn't be much of an improvement over what you have..
Old Jan 9, 2013 | 12:06 PM
Car: 1982 Trans Am
Engine: LU5 CFI
thank you for the links they will definetly come in handy when i start the transmission and diff swap. i know it wont happen for maybe another year or so but just getting ready now so im ready when the time comes.
Old Jan 9, 2013 | 12:08 PM
Car: 1982 Trans Am
Engine: LU5 CFI
so nothing from the front end of the 94 will fit the 82? i just want to make sure so i can start get that out of the way and find out what next to do.
Old Jan 9, 2013 | 12:20 PM
Engine: 383 SBC
Not really for suspension.
Old Jan 9, 2013 | 12:52 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
you cant run the 14' wheels with the 4th gen rear discs calipers rub
Old Jan 10, 2013 | 11:58 AM
BMR Tech's Avatar
Former Sponsor
Not a single front suspension item on the 4th Gen is shared with the 3rd Gen. The rear suspension is nearly identical down to the part numbers - meaning that none of the parts will be better than the parts already on your car unless they're in better condition.
The LT1 T56 will mount directly with our T-56 conversion crossmember or our Torque Arm Relocation crossmember. As for the driveshaft, don't hold your breath on it being the correct length, but it is possible.
- Kevin
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
