Spring Compressor WTF!!!!!????
Old Jan 11, 2013 | 06:45 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I must be stupid but I can't figure this spring compressor out. I went to the local auto parts store and got a spring compressor tool to put my springs in my a-arms. http://www.pepboys.com/product/details/9212033/
I put it inside the spring and after the spring is compressed the rod of the compressor sticks out the top of the spring 3-4". Then when I slide it into place that parts of the rod from the spring compressor will hit the center of the spring seat in the K member. So it wont work, am i missing something...The spring compressor fingers grab the coils fine and compress the spring but no matter what coil level I install it the rod sticks out of the top of the spring making contact with the k-member. The rod on the spring compressor is 12" and the Hotchkis spring is approx 12.5".
Old Jan 11, 2013 | 08:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spring Compressor WTF!!!!!????
You need a pipe nipple about 4 or 5 inches long to take up the extra room between the hex head on the threaded shaft and the first sset of fingers.
Old Jan 11, 2013 | 08:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For a pic of what you need, check post #7 of the following link:
https://www.thirdgen.org/forums/susp...nstalling.html
JamesC
Old Jan 11, 2013 | 08:58 PM
Yup, piece of pipe is the key. Seems like when I did that I had a 6" nipple. (when I bought it, girl at the hardware store said she wished she had a coupla those)
Old Jan 11, 2013 | 11:10 PM
Car: 89 Formula 350
thanks guys, i found an old post about the 6" pipe before I got back to this posting. I tried it, I got the spring to compress about 1 1/2 coils but still couldn't get it to seat. I all managed to do was scratch up the powder coasting, sucks. I was getting my *** kicked for hours trying to make it work. I'll try again tomorrow, I lost the battle tonight.
Old Jan 12, 2013 | 02:10 PM
Car: 89 Formula 350
ok, got them in using the 6" pipe sleeve in the spring compressor....that sucked!
Thanks for the help.
Old Jan 12, 2013 | 03:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use an old wrist pin as a spacer
Old Jan 13, 2013 | 08:15 AM
JunJun's Avatar
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
I still cannot fully understand this matter...
Is it up to where in coils I put the spring compressor?
Simply reversing the compressor doesn't work?
Old Jan 13, 2013 | 08:19 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Its because the threaded shaft of the spring compressor is too long for this application, no matter what you do it will stick out the top of the spring and hit the top of the spring pocket in the k-member. The piece of pipe takes up the extra slack, moving it to the bottom of the spring and sticking out the hole in the spring pocket on the control arm.
Old Jan 13, 2013 | 08:29 AM
JunJun's Avatar
Even without the piece of pipe, simply using the compressor upside down doesn't work?
Old Jan 13, 2013 | 09:11 AM
No.
The top of the spring is COMPLETELY inaccessible.
The reason you can't use the compressor as-is with the screw head on the bottom, is that the screw is too long to fit that way; the threaded end would stick out the top of the compressed spring and hit the top of the spring pocket.
The way to do it, is with the pipe.
Old Jan 13, 2013 | 09:45 AM
JunJun's Avatar
No.
Oh, I see.
Then, a piece of pipe or a shorter threaded shaft will be needed.
Thanks for the reply.
83 Crossfire TA
Jan 3, 2016 01:26 PM
customblackbird
Oct 1, 2015 04:30 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
