Drag suspension setup
Car: 1985 z28
Engine: carb 5.3 turbonetics t78
Transmission: th400
Im building up a shopping list for my front suspension as of now. Just wanted some pointers...
Car is getting a basic 5.3 with cam, 150-200 shot of nitrous. rossler th400, 3:55 gears.
Will be ran on DR's most the time. Not gonna be at the track too often, just want something that hooks hard on the street.
Im planning on getting koni spa1's up front, with moroso trick springs.
In the rear, will be qa1 18 way single adj shock on stock v8 springs.
Have founders panhard, and LCA's, LCARBs if necessary.
Just wondering if theres anything wrong with this current plan, or if anyone had any tips? thanks.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Drag suspension setup
double adjustable rears at least are needed for drag radials on the street. Why such small rear gears also?
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Car: 1984 Z28
tires are most important as is the whole package. Do you at least have 90/10s up front ?
He mentioned drag radials, so they need a good double adjustable shock to get the chassis to do what you want. Getting the weight transferred and the tire hooking is key.
Car: 89 Formula 350
In my case I don't have adjustables up front. I just put in a set of new KYBs up front and not looking to change them out anytime soon. I do run drag radials also with non adjustable KYBs(older) out back. I just saw you mention double ajustables for the rear and was curious how much they would help with non adjustables up front..my mods in sig above.
Car: 1985 z28
Transmission: th400
Why do you say doubles are needed with drs? I know of a good chunk of people running singles in the rear and hitting 1.2-1.4 60'..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's a tuning aid. With double adjustable shocks, you can fine tune both directions for all track conditions. One setting does not work under all situations.
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
A good rigid torque arm is a good investment too. Especially if your in the low 7's 1/8 / 10's 1/4. Dropped my 60' too.
Car: 84 camaro
Engine: HRE 355
Transmission: th350
Axle/Gears: 4.56
The trick springs arent really worth the trouble IMO....rear shocks, 90/10 fronts and a good torque arm will work wonders.
Car: 89 Formula 350
Car: 1984 Z28
Midwest makes a third gen torque arm....just be a bit of a wait on it.
i talked to both mad man and midwest this morning both of them have torque arms that will work with the third gen. i went with the midwest chassis torque arm its a pretty sweet piece.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
