Lowered with 19s...... need some alignment specs please
Old May 6, 2013 | 09:41 AM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
As the title says, my 86 is lowered 2in all the way around. The front has Racecraft 2" drop spindles with Moog constant rate springs. I have 19x8 on the front corners and I need to get this thing in for an alignment. The stock specs are awful for our cars. Would anyone have any advice on how to set this thing up for a setup like mine? It's mostly street driven with aspirations of a road course event or two in the future. Thanks in advance.
Old May 6, 2013 | 01:48 PM
midnightfirews6's Avatar
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Re: Lowered with 19s...... need some alignment specs please
Caster: +4.5/+5.0 (depending on how much you can get... go for as much as possible on the passenger side and half a degree less on the driver side, +4/+4.5 for example)
Camber: -1/-1
Toe: 3/32" for stock a-arm bushings, 0 if you're using del-alums or aftermarket a-arms with delrin bushings.
Old May 6, 2013 | 02:28 PM
SlickTrackGod's Avatar
On Probation
Camber: -1/-1
Caster- fully agree
Camber-He would get too much inside tire wear with 19's-why? the sidewall aspect is too low and the tire footprint is too rigid. Better off with about -0.7 each side.
same with toe- I would stay 3/32 in regardless or the car will start to get twicthy at higher speeds
Copchaser- search the forum on the Racecraft spindle failure. Better safe then sorry. members have had some serious issues with them.
Old May 6, 2013 | 09:31 PM
Copchaser's Avatar
Originally Posted by SlickTrackGod
Caster- fully agree
Thank you fellas. I have read about the problems these spindles have caused other members. I've had mine for quite some time now and haven't experienced any issues (knock on wood). Thanks for the heads up.
Now as far as both of your toe recommendations are concerned, I have the stock a-arms with poly bushings. Should I still stick with the settings you mentioned?
Old May 6, 2013 | 10:11 PM
Yup...
The direction things are pointed is largely independent of what they are made of.
Old May 6, 2013 | 10:17 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
We went as far as we could on caster(forgot the number) and at -.5 on camber. Much better than how it was...
We stayed 3/32 on the toe...
I'm lowered 3" or so(Sportlines) with adjustible camber/caster plates... 19x8 and 19x10
Old May 7, 2013 | 09:05 AM
Copchaser's Avatar
Awesome! Thanks a lot guys
Old May 7, 2013 | 01:17 PM
On Probation
Yup...
As I agree with the yup part, the rest of it is not the reason I suggest he stay 3/32". It is not independant of what things are made of, he needs to stay 3/32 because of teh material and makeup of the tire design is alot more ssnsitie to change and has less delfection in slip angle A larger aspect tire will give a little even in positive toe at high speed, the low profile will be all over the place in a straight line. It needs the slight toe in becasue it is far less forgiving. tire footprint quality will dominate setback
Old May 10, 2013 | 12:41 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
hey guys, sorry to butt in, but i have the same question, im not happy with my alignment. the car feels planted but i know i can get alot more out of her, i am 2 in drop on hotchkis springs, 18x10 wheels at all four with continental conti sports 275 35 zr 18 tires. i am building tie rods with heims and racerunner and i are designing a custom front struts with internal resi's and in making my own strut mounts with 3/4 inch shaft..... any help on setting for my alignment would be fantastic
Old May 11, 2013 | 01:03 PM
morrow's Avatar
Car: 92 Camaro Rs.R
anyone? lol
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
88rscamar0
Sep 23, 2015 09:08 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
