what would be a good/fair price for getting my rear my rear lower control arms boxed
Car: 86 Camaro Z28
Transmission: TH 700R4
before i start looking around i wanted to know what a good price would be to get my rear lower control arms welded shut and looking nice. i would be the one to remove them and take em back to bare metal, the welder would just have to supply the plate and weld em and clean em up... so whats fair?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: what would be a good/fair price for getting my rear my rear lower control arms bo
Is there any reason for not considering after market?
JamesC
JamesC
Car: 1991 Camaro RS
Engine: 305 TBI
I bought a complete set from founders performance including the panhard bar for around $130. Welded tube construction looks good a fit perfect.
Your proposal is nonsense. Wrong question. Spend more, get less. WHAT A DEAL!!!
Messing with the stock crap is a total waste of time money and energy.
Look at the board sponsors; Lakewood; Hotchkiss; etc. ALL of em better than the stamped sheet-rubber garbage these cars came with. Boxed or no.
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
free.. if you have a buddy with a welder and some scrap steel laying around.. it would also be a good opportunity to learn how to weld..
but honestly, how much benefit do these cars get from boxed rear lower control arms? it's not like a 4 link car where all the torque is transferred to the chassis via the upper and lower control arms- most of the torque is transfered to the chassis via the transmission thru the torque arm and all the arms do is hold the axle in place fore and aft.
Car: 86 Camaro Z28
More than a good aftermarket set.
The LCAs transfer EVERY OUNCE of accelerating force to the car. The torque arm transfers EXACTLY ZERO "pushing" force.
The ABSOLUTE WORST REASON there is, for continuing down a path of making a series of mistakes... known as the "sunk cost" fallacy. http://en.wikipedia.org/wiki/Sunk_costs Show us that you're smarter than that, by not falling into that trap.
i already own
Car: 86 Camaro Z28
The ABSOLUTE WORST REASON there is, for continuing down a path of making a series of mistakes... known as the "sunk cost" fallacy. Sunk costs - Wikipedia, the free encyclopedia Show us that you're smarter than that, by not falling into that trap.
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
If it means anything, I boxed my control arms and installed poly bushings, and it made a HUGE difference in eliminating wheelhop. If your friend is only charging you 30 bucks, I say go for it. 30 bucks is peanuts.
Car: 86 Camaro Z28
thank you man, i does mean anything to hear that. I had read that boxing w/poly bushings improved things a lot which is why i bought the bushings a decade ago in the first place, Its the difference between spending 30 and 100-250 for what ends up being the same thing. He's gonna weld up the bottom with 3/16 plate and reinforce the rest, then he's gonna grind it all smooth and powdercoat it for me.. not a big deal to him since his family owns an established race shop down the road. so did you do 1/4 miles in it, road race or just enjoyed a little stoplight fun?
Car: 86 Camaro
you're right... i was thinking weird before... but there is no twisting force on the control arms like there would be in something like a G body that mounts the sway bar directly to the lower control arm- all the forces in a Camaro are going to be pushing straight down the length of the control arm, with maybe a little "twist" being applied with stock rubber bushings that have a little bit of bind to them. so just visualizing how things operate, boxing the stock arms will add a little bit of weight and maybe a little stiffness. aftermarket tubular arms would help because they won't usually have rubber bushings and they will be lighter- which brings up another option for the OP- get some tubing and have your welder friend make some tubular control arms..
Car: 86 Camaro Z28
i actuall had already considered that, i may not have a welder but i can cut the tubing myself but the ride would be significantly more rough with solid arms and it would cost much more than the 30 bucks i am pretty much planning on by now
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Car: 86 Camaro Z28
actually i had the jegs page for em open already at the time- thats their prices for them.. i know you can get em cheaper on ebay and what not but there ya go.
The basic Founders LCAs would still be superior to a set of boxed stock arms IMO.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I have a welder and if you were a buddy it would cost coming over with a case of beer hell and I can powdercoat them too that would cost at least coronas but most shops charge 30 to 50 buck a weld so you could be at 60 to 100 then its not worth it but 30 for the pair is fair alittle steep for a buddy price if you ask me though
I built my own pan tq arm and lcas for 200
Car: 86 Camaro Z28
AND boxed arms are far superior to stock untouched
) Thread Starter
Car: 86 Camaro Z28
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Seems to me that if you have good bushings, and some steel, and welder access, there is no reason NOT to try it. The first boxed lca were probably used on the second fbody race car ever built. If you lived near me you could probably borrow the MIG and do it yourself. The most time consuming part is cleaning and setup of the weld surface, which you can do. welding time is only a few minutes.
Car: 86 Camaro Z28
looks like i need to start askin around to the people that are a tad closer to me, honestly from what it seems is that i would be payin 30 bucks for somethin that could be done in the time it take to drink a beer- maybe less for some people. however the fact that its gettin reinforced and powder coated factors in heavily... but since i am doin the prep work i am doing most of the work anyway
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
