will 4th gen T/A rearend work in 3rd gen camaro
Old Jun 22, 2013 | 12:50 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
I found a junk yard with about 20 or so fbodys sitting around. They had several 4th gen trans ams with rear disc setting on ground. Can I install a complete rear end into my 86 camaro?
Old Jun 22, 2013 | 05:07 PM
Re: will 4th gen T/A rearend work in 3rd gen camaro
https://www.thirdgen.org/forums/tran...-10-bolts.html
Old Jun 27, 2013 | 02:02 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
will stick out if your using stock thirdgen wheels.... im running a torsen ls1 rear on my 88 gta.. I plan on keep the 4th gen style rear so I can run deep dish zr1 rims with 315 tires on the rear someday
Old Jul 1, 2013 | 09:24 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I am using a rear end out of a 2000 pontiac trans am right now. Just run fourth gen wheels on the rear and spacers in the front. You will not fit 315 series in the rear unless you have the inner fenders tubbed or the tires sticking out the sides a good bit.
Old Jul 2, 2013 | 06:05 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Will need to change the proportion valve if you are going from drum rear to disk. If you dont the rears wont hold.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
dhonda200
Aug 11, 2015 11:50 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
