Car is a 4x4. Why
Old Sep 3, 2013 | 07:42 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Car is a 4x4. Why
Got car back together this spring. Has bin without a motor for 6 years or so
And the front end is way up high. Measured 29" on both sides
Did springs stretch??
It's all new kmember struts brakes and bushings
Springs are located right. Cover one hole but not other on a arm any thoughts
Old Sep 3, 2013 | 08:08 PM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
Re: Car is a 4x4. Why
When I replaced the old totally worn out front shocks on my Fiero the front end raised up I'd like so say about an inch.
Old Sep 3, 2013 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Move the. Car around first and see where its at after it settles
Old Sep 3, 2013 | 09:33 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Car has bin driven plenty this summer still high it did settle a bit but not much
Before I could get jack under kmember now it's a tight squeeze
Old Sep 4, 2013 | 08:53 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
No ideas
Old Sep 9, 2013 | 03:11 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
OEM K-member or aftermarket????
Old Sep 9, 2013 | 06:04 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Spohn k member
Stock arms
Old Sep 9, 2013 | 08:07 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
everything will need to settle for a bit before you can decide what your ride height is, put some miles and wiehgt on it for a while see where it sits and then decide if you need to lower or what not.
Old Sep 10, 2013 | 12:57 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
Spohn K-Members have had some issues in the past if I remember right about this issue. Also how much weight did you remove from the front end? Alum Heads, headers etc...... an extra 50-100 lbs will cause it to ride higher as well.
Old Sep 10, 2013 | 02:01 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Ya kwik I think it is a weight thing
Hood heads and all the basic stuff gone
But I added a 45lb turbo and some piping but it must still be light
And kwik u wouldn't of bought that car from me like 8 years ago did u?
Old Sep 10, 2013 | 02:09 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
I have had the car since 1994...
Was doing some re-reading, you could get a jack under the K-member before when it sat lower, but now you can't? If you have access to the stock K-member measure from your spring seat to the center bolt holes for the lower control arms, just to check that the Spohn piece is the same distance.
Old Sep 10, 2013 | 02:25 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
That is about when I sold mine
Did u get the car with a cowl hood?
Just a roller?
No I must of worded it wrong the car has dropped a 1/2 in I used to get jack under kmember right when I got it done now I can't but is is still up high
Old Sep 10, 2013 | 02:34 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
No I bought the hood from VFN about 5 or so years ago, when I bought it was a complete L69, T5 car that I drove through college.
From the sounds of it then the springs have settled, I would check the dimension mentioned above. From the sound of what you are saying it sounds like that measurement isn't right.
FWIW my car has stock k-member and arms, with trick springs and 1 coil cut off IIRC with 165 front runners, no weight left in the front end (iron headed small block, but completely stripped out engine bay) and my measurement is about 26.5"
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
