Replacement Horn contact.
Old Oct 14, 2013 | 12:23 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
Mine is broken.
Are they available new? I've been looking but haven't found any. If new is available, is it quality that will last another 20 years or junk that I'll have to replace next year.
If not new, which cars can I get one from at a junkyard? Mine is an '88 Firebird Formula, manual, tilt.
Old Oct 14, 2013 | 12:29 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Replacement Horn contact.
They can be bought new at just about any chain parts store(Autozone, Advance Auto Parts, Pepboys, etc). I bought mine a Autozone a few years back for about $5. They are in the "Help" section at Autozone, probably in a similar section at other stores.
Old Oct 14, 2013 | 04:15 PM
Engine: 305 (LO3)
Got one, thanks.
Old Oct 15, 2013 | 07:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The turn signal switch has a spring-loaded nub that contacts the brass connection on the underside of the turn signal cam. Thoroughly cleaning it with a bit of steel wool is probably a good idea since you have everything apart.
JamesC
Old Oct 15, 2013 | 08:13 AM
Engine: 305 (LO3)
It was shiny, no corrosion that I could see, so I wiped it off, applied some dielectric grease and got it back together. Everything seems to be working.
Old Oct 15, 2013 | 08:17 AM
JamesC's Avatar
Good to know. The ring and contact were dirty enough in my car that the horn was intermittent.
JamesC
Old Sep 29, 2014 | 06:48 PM
AJ_Maine_Man's Avatar
Hello,
Mine is also broken where did you find the part? do you have a link?
Old Sep 29, 2014 | 09:00 PM
JamesC's Avatar
Dorman part number in the following link:
https://www.thirdgen.org/forums/elec...orn-fails.html
JamesC
Old Sep 29, 2014 | 09:26 PM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
rockauto has them...I got one at o'reilly's.....
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
Fronzizzle
Aug 9, 2015 01:15 PM
