Suspension Problem? HELP!
Old Jan 21, 2014 | 06:50 PM
shaubloom's Avatar
Car: 1988 Pontiac Formula Firebird V8 5.
A few weeks ago my 1988 Pontiac Firebird started making a creaking/clunking noise on the right rear side. I thought the rear shocks needed replaced, so I replaced so those brand new. The noise didn't go away, and seems to be getting worse.
Here are two links to videos where I recorded the noise on my Youtube channel, please take a listen:
All help is appreciated and all help solving this would be greatly appreciated; as I am a beginner!
Old Jan 22, 2014 | 08:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Suspension Problem? HELP!
This is happening just when you turn to the right, Sooooooooooo have you checked out the front wheel wells to see if your tires are rubbing any where.
Old Jan 22, 2014 | 08:35 AM
Edwardgp's Avatar
Engine: 454-350
Well I have re-read the post and see it is coming from the rear end Sorry. OK then if we are lucking it might be a wheel bearing or a loose brake. Do you know if you have rear drum or disc brakes?
Old Jan 22, 2014 | 08:40 AM
Edwardgp's Avatar
Engine: 454-350
I would also make sure that all the lug nuts are tight on the rear wheels. Just a few things to check out Shaubloom. Have you had the cover off of the rear differential for inspection yet?
Old Jan 22, 2014 | 08:42 AM
Edwardgp's Avatar
Engine: 454-350
You should also check for a possible bent rear axle. Are you going to do the work yourself?
Old Jan 22, 2014 | 09:28 AM
SlickTrackGod's Avatar
On Probation
Originally Posted by shaubloom
Help a girl out guys!
Sounds to me like someone was already "helping you out" in your back seat.
On a serious note- Lets listen to the obvious. Something is rubbing as the assembly spins. That equals something being misaligned or bent. Take it to a professional shop and have them inspect it. It does not sound safe. I would sugggest having it towed to a repair shop.
Anyones guess without seeing it in person would simply be- a bent axle, or a bent wheel, or metal on metal brake componants completely worn down(internal brake drum assembly)
Old Jan 22, 2014 | 11:53 AM
83 Crossfire TA's Avatar
What are you doing to it in the videos to make that noise?
Old Jan 22, 2014 | 03:37 PM
shaubloom's Avatar
Rear Passenger side.
Old Jan 22, 2014 | 07:30 PM
On Probation
The second video sounds to me like she was standing there recording noise as someone drove the car past her at about 5 MPH. My strong guess is the brake drum is warped and brake shoes are gone (extremely worn out) and making that pulsing grinding noise as the car rolls past.
EDIT: ..I listened again- make that a 10-15 mph pass, not 5
Old Jan 23, 2014 | 04:14 PM
shaubloom's Avatar
The car is actually parked... If I were to drive on the smoothest surface, the noise wouldn't happen. Any little bump, speed bump, anything to make the rear end of the car bounce up and down makes the noise. To make the noise in the video, we were pushing down on the rear end of the car repeatedly to make the noise. It doesn't happen at all when I use the brakes. When I first replaced the shock absorbers it actually stopped and seemed to fix it for about a week. Then the noise came back about a week later.
Old Jan 23, 2014 | 04:16 PM
shaubloom's Avatar
The car is actually parked.. We are bouncing the car up and down in the back to get the noise. It doesn't make the noise when braking or driving without bumps.
Old Jan 23, 2014 | 04:17 PM
shaubloom's Avatar
This just started happening randomly and progressively got worse.. Would a rear axle randomly bend?
Old Jan 23, 2014 | 04:43 PM
Chad85T/A's Avatar
Car: 85 T/A
Has an exhaust hanger came loose letting the pipe that goes over the axle rub against something maybe?
Old Jan 23, 2014 | 05:28 PM
Edwardgp's Avatar
Engine: 454-350
OK now we have more information. You will have to get under the car on jack stands if need be. Have some one push down on the car and see what is going on.
Old Jan 27, 2014 | 06:04 PM
shaubloom's Avatar
Thank you everyone for the help! I was able to purchase some Rhino Ramps and pinpoint what was going on. The spring slipped out of place somehow after installing the shock absorbers. Positioned spring back into correct place and fixed issue. Thanks all!
Old Jan 28, 2014 | 09:35 AM
Edwardgp's Avatar
Engine: 454-350
Great thanks for the update.
customblackbird
Aug 15, 2021 10:16 PM
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
