finally lowered!
Old Mar 26, 2014 | 09:49 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
finally lowered!
Cut front and rear ws6 springs. 1 1/2 in the front and only a half in the rear. Need to lower the rear some more. Should I just remove the insulators or take another half off?
Old Mar 26, 2014 | 09:50 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Pictures
Attached Thumbnails finally lowered!-forumrunner_20140326_105019.png   finally lowered!-forumrunner_20140326_105030.png
Old Mar 26, 2014 | 04:53 PM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Re: finally lowered!
i cut 1 coil front & rear & removed the rear isolaters & put 1/2" heater hose on the coil in its place sits about 1/4" higher in the rear so might want to try that & see where it sets then you can always trim a bit more if still not happyName:  lowered005.jpg
Old Mar 27, 2014 | 07:23 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
That looks pretty good! I have another set of stock springs so I'll try cutting another half on the rear and maybe swapping isolators. If that doesn't work I'll start all over.
Old Mar 28, 2014 | 05:02 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Took the stockers and did 1 coil front and rear and removed the rear isolators. Sits perfect I think! Handles really good and don't have any problems rubbing or scraping
Old Mar 28, 2014 | 05:03 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Old Mar 29, 2014 | 02:09 PM
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Looks good nice stance & still very drivable height
Old Apr 3, 2014 | 06:31 PM
the fox's Avatar
I just bought a set to lower mine 2" front and back and I have 18" rims I get no rubbing im really happy with itName:  20140302_142826_zpsaee38ff1.jpg
Old Apr 3, 2014 | 07:00 PM
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
that looks good fox what size tire do you have im looking around for new wheels/tires not shure on 17s or 18s
Old Apr 3, 2014 | 08:38 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There were many different spring rates for stock springs, which rate springs are any of you using? Do any of you run into the bump stops during driving? I am using the part number 5664 springs that are rated at 767lb/inch and have one coil cut and am not as low as you guys are posting. Are you using old springs? I know my setup may be lighter but I am probably still 1-2" higher than you guys.
Old Apr 4, 2014 | 03:32 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
How light are you?
Old Apr 5, 2014 | 01:10 AM
Tibo's Avatar
Car: 1991 Z28 Vert
No idea, I haven't found a scale since I started in on this car.
Old Apr 5, 2014 | 06:50 AM
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
i didnt buy new springs just cut the ones already in the car its at 25 3/4 from floor to center of finder lip in front with 245/50/16 1 coil gave me about 2" drop i want to say the tag on the spring was mk54 but i cant remember sorry
Bubbajones_ya
Jul 6, 2024 08:32 PM
J-money
Jan 4, 2019 09:45 AM
tommy z-28
Oct 6, 2015 10:58 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
