sway bar? 34mm front /30mm rear
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok well i have been looking for a hour found some good info but not sure if i or were i fall under it .Because of my rear sway bar size i have a 34mm stock sway bar and this 30mm rear sway bar ,it also has to spots for the end link on it . My worry is will i over size my front sway bar with this 30mm rear say bar most ppl are saying they run the 36mm with the 24mm rear sway bar? i plan to road race this car maybe do them parking lot time attacks and drive it on the street most of the time
Re: sway bar? 34mm front /30mm rear
34/30 is going to set the car up LOOSE LOOSE LOOSE if everything else is typical-ish.
Stock, the 34 was usually mated with a 22 or 24 rear.
Since sway bar stiffness is approximately proportional to the CUBE of the diameter, a 34 will be at least 2½ time as stiff as a 24, if all else is equal. Probably lift the inside rear tire around hard turns on the brakes. (if it's lucky enough not to just spin out)
That's probably actually an "anti-roll bar" for drag racing; not a "sway bar" at all.
Car: 92 camaro rs
Engine: 3.4v6 sc
well both pars came off the same car guy had jamx springs in rear and eibach in front
Not the right parts for your application.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My 34/24 setup has me complaining all the time because my 24mm rear bar is just too big for me. I need a smaller one.
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
I have a 87 firebird with ws6 suspension. I measured with digital calipers and it has 36 front and 24 rear. I'm having a hard time finding frame bushing on the 36mm front. Anyone got any ideas? Respect.
Axle/Gears: 3.45, 3.27, 3.27
Yes, I sell the 36mm front bushing kit in red or poly-graphite black.
Lon
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
