Steer Gear Rebuild: Identifying Box
Old May 23, 2014 | 11:21 AM
87camaro kid's Avatar
Car: 1987 Z28
I have been searching for a while but cannot find out how to determine what steering box I have. Is there a code stamped on the box?
I have an 87 Camaro Z28 with the stock box. RPO codes where removed by previous owner.
Old May 23, 2014 | 02:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Steer Gear Rebuild: Identifying Box
There was a 2-letter code stamped in ink on the box. It is on the end that is opposite the input shaft, and it is on the top cover (with the 4-bolts). However, the ink comes off very easy, so many times it no longer exists.
Which is unfortunate as otherwise need to pull the box apart to ID it.
RBob.
Old May 23, 2014 | 02:12 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Its likely going to be the normal ratio box, and not the quick ratio boxes that came equipped on the more high option cars.
I have a Lee's 670 gear now, but still have the quick ratio box for my TransAM, but it needs to be adjusted, if not rebuilt entirely.
Old May 23, 2014 | 02:57 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Cant you just count the input turn range? The slow ratio box is 3.5 turns lock to lock, and the fast ratio box is 2.5. It should be pretty close to one or the other, right?
Old May 23, 2014 | 03:03 PM
Car: 1987 Z28
How can I ID the box once it is taken apart?
Old May 24, 2014 | 09:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Need to know what to look for, along with dimensions. The three main items are the thickness of the stops, the diameter of the torsion bar, and the ratio of the ball & worm rack.
RBob.
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
Linson
Aug 21, 2015 02:12 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
