need spring advice( moogs suck)
Old Sep 30, 2014 | 06:47 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
long story short I replaced my springs on my 88 with moog springs on all 4 corners and the fronts are hideously too high. about a 4 inch gap between the tire and fenders. ive searched on here and it seems that im not the only person to run into this problem with moog....so I need to replace them and I would like advice on what I should put on it....I replaced everything when I did the springs such as the struts , shocks, and sway bars so I really don't want to replace all that again. my car looks like a 4x4 right now. please help! you might be able to seen in this picture.
Attached Thumbnails need spring advice( moogs suck)-10152519_10200907868177536_21470448667306182_n.jpg
Old Sep 30, 2014 | 07:12 PM
deadman's Avatar
Car: 89 camaro
Re: need spring advice( moogs suck)
can I put the hotchkis 1 inch lowering springs without changing everything again? I would do the front and rear if I could do it without needing to change everything and weld lca mounts to the rear.
Old Sep 30, 2014 | 07:44 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
are you sure you indexed the front springs correctly? if you did not install them properly that would be exactly your problem. Its a very common mistake.
Old Sep 30, 2014 | 08:18 PM
deadman's Avatar
Car: 89 camaro
Yea everything is correct
Old Sep 30, 2014 | 08:50 PM
GCrites80s's Avatar
Car: '87 IROC-Z
Engine: TPI 5.7
"Looks like them Duke boys have some competition in the Hazzard Derby"
Old Sep 30, 2014 | 10:33 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Originally Posted by deadman
88 . my car looks like a 4x4 right now. please help! you might be able to seen in this picture.
Your's Doesn't Look That Bad,Now That Mopar In The Backround Is A Differernt Story.
Old Sep 30, 2014 | 10:45 PM
Alice89's Avatar
Man that front end is sitting really high. You can install lowering springs without replacing any of your other suspension pieces that you say you recently installed. You will have to get the front re-aligned; and it would be wise to get an adjustable panhard bar too. (but you don't have to)
Old Oct 1, 2014 | 07:07 AM
deadman's Avatar
Car: 89 camaro
Would hotchkis 1 inch drop spring be the best for me or eibach or something else? I'm not autocross or drag racing just going to car shows and cruising mostly.
Old Oct 1, 2014 | 08:50 AM
Car: 92 Camaro RS
I definitely recommend eibach over hotchkis. Hotchkis spring rates aren't any better than stock for our cars. If you had a 1st gen then I would recommend hotchkis.
Old Oct 1, 2014 | 10:02 PM
LastDance's Avatar
Car: 91 Z28 Camaro Convert
Engine: 305,Edel,Comp,Hooker
Put the Eibach 1" lowering street version using the outer A arm release, compressor with the mod to avoid center screw interfering with K member seat, and the jack (factory releases the inner connection of the A arm). First try it sat just like yours and was correctly indexed on the A arm. However the center screw on the compressor had caught off center on the hump in the K member which hung the spring up on the hump as well. Had to shine a bright light up into the K arm to see the spring hung up on the hump.Once getting the spring off the hump and into the seat it sat fine, rides great, and has settled slightly more with time. Then again maybe Moog springs do ****.
Old Oct 2, 2014 | 07:01 PM
deadman's Avatar
Car: 89 camaro
I just got the eibachs in the mail today , hopefully get them in sunday.
Old Oct 12, 2014 | 02:52 AM
Alice89's Avatar
So did it help even out your ride height?
Old Oct 12, 2014 | 08:02 AM
deadman's Avatar
Car: 89 camaro
yes it did and the ride is soo much better...I went from around 28 inches from the lip to the ground to 26 3/4. I didn't do the rear yet. and it is 28 1/4 from the ground to the lip. as a comparison the eibach spring had about a coil and a half less than the moog.
Old Oct 12, 2014 | 08:09 AM
Alice89's Avatar
Awesome! Post up some pics when you get the rear done. I bet it will look sweet. Besides the stance your car looked really good in the picture above...
Old Oct 26, 2014 | 09:54 PM
spicyskater's Avatar
Car: 1987 camaro Z28
Transmission: manual
what moog part number u used ...there is diferent rates!!! there is 3 part numbers soft mid hard ...i would guess u used hard if there is nothing else wrong with your suspension
Old Oct 27, 2014 | 12:52 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
i have the stiffer of the MOOG springs..my car looked like the OP's car so i then cut off a few coils and got it straight..cutting more off soon too..rides great
Old Oct 30, 2014 | 08:47 AM
E.Roy's Avatar
Car: '82 TA
Engine: Carb'd 350 w/ Vortecs
Transmission: Super T10 4-spd
Like Mikey said on cutting the MOOG's, there is some good info in this thread for future readers of this thread
https://www.thirdgen.org/forums/susp...og-5660-a.html
Old Oct 31, 2014 | 08:52 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
What I got with Moog 5662/5665
LF 27.3 RF 27.5
LR 28.75 RR 29
How much did the Moog 5662 change my front heights?
LF +0.5" RF -0.25"
Everybody seems to get a different result with springs and car height. Mine went up on the driver's side front and down on the passenger side front. Yet the result was that the car was level with a 0.2" difference side to side. Better than before as the driver's side was much lower than the passenger side prior to replacing springs.
If you're happy with the lowering springs, then I say all is well. Personally I kind of wished that my front end was in the 28" range as there are way too many speed bumps and steep driveways where I live. (Prone to flooding, so everything has a steep entrance). On the other hand, it gave the car a nice raked look.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
mrdevontay
Sep 2, 2015 08:04 PM
