Eibach, summit lowering springs any others to look at?
Old Feb 21, 2015 | 11:04 AM
SOCAL-Z's Avatar
Car: 87' IROC
Looking at Summit lowering springs and Eibach pro and sportline springs. Any other brand I should look at. Going to replace the 27-28 year old springs when I replace the shocks and struts on my 87 IROC project. Any problems with going with lowering springs?
Old Feb 21, 2015 | 11:12 AM
Podium's Avatar
Re: Eibach, summit lowering springs any others to look at?
I have always heard good things about Vogtland. I am using them but I have not driven the car. I have had eibachs on third and 4th gens but I thought they were alittle harsh.
Good price as well
http://www.foundersperformance.com/c...ird-1982-1992/
Of course replace other suspension pieces as well if they are worn.
Old Feb 22, 2015 | 09:31 AM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
What springs are best for you really depends on what you are going to do with the car.
IIRC, the vogtland springs are a dual rate. Some of the coils collapse creating a number of dead coils which will increase spring rate of the remaining coils but there is only so much room in there and i would be concerned about coil bind if used for autoX or road racing.
Linear/constant rate springs are best for handling. The other kind is progressive/varible rates. Eibach has linear fronts and progressive rears. Not a bad option depending on what you are going to do with the car. I would choose Eibach over Vogtland if i had to pick from those two for my car, but keep in mind that my opinion takes into consideration what I use my car for.
Old Feb 22, 2015 | 10:50 AM
SOCAL-Z's Avatar
Car: 87' IROC
Just going to use it to drive around town and attend local shows.
Old Feb 22, 2015 | 11:01 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
So do you prefer the lowered or the slammed look?
Old Feb 22, 2015 | 01:24 PM
SOCAL-Z's Avatar
Car: 87' IROC
Just lowered so I don't drag the nose and pipes all the time.
Old Feb 22, 2015 | 02:33 PM
Car: 92 Camaro RS
If appearance is what's most important to you, then it's not a big deal which springs you use. It makes more of a difference if your modding for performance. Good call though, these cars look great lowered an inch or two. Eibach is a nice choice.
Here is a GREAT thread for viewing all the different springs. https://www.thirdgen.org/forums/susp...d-3rd-gen.html
Old Feb 22, 2015 | 02:47 PM
Podium's Avatar
And be sure you "index" the spring!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
