Suspension help
Old Jun 23, 2015 | 08:27 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
Suspension help
Wondering if anyone has installed one of these kits on there car
Old Jun 23, 2015 | 08:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Suspension help
Not sure the brand but its done all the time.
only parts worth buying are moog brand, most everything else is garbage and you will be replacing it again soon. Im being serious, there are tons of kits on the market, even some by supposidly respectable vendors and site sponcers, and the quality is horrible. Moog it the only way to go. Acdelco is usually fine and sometimes napa uses repackaged moog parts.
Old Jun 23, 2015 | 08:48 PM
Car: 1989 rs coupe
Re: Suspension help
Its from world wide suspension on eBay quick job?
Old Jun 23, 2015 | 08:53 PM
Car: 1989 rs coupe
Re: Suspension help
Mas industry
Old Jun 24, 2015 | 07:10 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Suspension help
Second the moog only. Anything else is a gamble. Can often get moog at good prices at rockauto.com
Old Jun 25, 2015 | 10:29 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Suspension help
Am I the only one who noticed the kit has upper ball joints?
Old Jun 26, 2015 | 09:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Suspension help
Agreed. There are a couple parts suppliers that will repackage moog parts and leave the moog name on the part or the moog part number. I know for certain that at one time on some parts AutoZone repackaged the moog as theirs. Timken is the same way.
Old Jun 26, 2015 | 09:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Suspension help
Pass on the stamped steel clamp version of the tie rod adjusting sleeve. Buy the piece that looks like a four inch long nut. Here is the Spohn version: http://www.spohn.net/shop/1982-1992-...Adjusters.html
The stamped steel can bend and be temperamental.
Old Jul 23, 2015 | 11:33 AM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
Re: Suspension help
i agree. moog is where its at! love the product.
Old Jul 24, 2015 | 04:31 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Suspension help
the stock replacement stamped steel sleeves are plenty strong: i've replaced a few bent tie rods from people hitting curbs and the sleeves were still perfectly straight.. put a little anti-seize on the threads and try to have the open slot down so water drains out when you are done, and they won't fight you in 5 years if you need to adjust them... the only benefit of the aftermarket pieces- other than making a part of the car that no one will ever see look like a race car- is that they usually have wrench flats on them to make adjustments easier, which is really only important on race cars and street cars that hit the road course once in a while.
Old Jul 24, 2015 | 10:03 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: Suspension help
You haven't personally seen a bent tie rod adjusting sleeve and you think then that means the product is useless unless you're a race car driver because only they are allowed to own a part that makes life easier or their car safer. Am I right or where am I wrong?
Old Jul 24, 2015 | 10:10 PM
Car: 1989 rs coupe
Re: Suspension help
U ate right I'll give u that but sadly any suspension and sterring part upgrades will have to wait my 3.4 swapped motor has died on me and I wanna get it back before I move on and fast too any help there would be appreciate ( I have a thread else wear for it
Old Jul 28, 2015 | 02:57 AM
novaderrik's Avatar
Car: 86 Camaro
Re: Suspension help
no, it means that money is better spent on other areas of the car.. my personal experience with these things is that their only benefit is making alignments only very slightly easier and your wallets slightly lighter. they rank right up there with chrome valve covers and fuzzy dice in the pantheon of things that make your car better in any measurable way.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
