Spohn spherical end links anyone using them?
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
Title says it's all. Just found out that they existed.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spohn spherical end links anyone using them?
Nothing earth shattering about them. Unless you need the bumpsteer adjustment the stock ends are much more durable. Just maybe swap the stock adhuster slea es for some heavy hex obes
Car: 92 Camaro Rs.R
Transmission: wc t-5
I think he's referring to the rear lower arms.. The biggest thing about them is there is no deflection and they are fully adjustable and rebuild able if I recal. And they don't bind... Also they are way more durable that heims
If your looking for options for bind free suspension components that don't give you the harsh rod-end ride we manufacture roto-joints which have the articulation but have a delrin race that will give you more of streetable ride compared to the harshness of rod ends.
http://umiperformance.com/catalog/in...roducts_id=389
If you need any info or pricing fell free to contact us.
Craig
Craig
Car: check
Engine: check
Transmission: check
And the answer is: D - none of the above:
http://www.spohn.net/shop/1982-1992-...-Firebird.html
OP, helps to post a link...
RBob.
RBob.
Car: 92 Camaro Rs.R
Ohhh sway bar links!!! Yes helps to specify lol I use something like this but I bare mine with parts from art Morrison chassis mfg. they just have less diflection and more movement in them so they bind less...
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
db057
Aug 11, 2015 10:11 PM
