Looks like Morrison has a more compact version of their IRS available
Old Aug 22, 2016 | 09:30 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Click here for suspension pr0n
Not even going to talk price but it looks like it would be the easiest fit and would be the best design to work from.
Old Aug 23, 2016 | 12:43 AM
SlickTrackGod's Avatar
On Probation
Re: Looks like Morrison has a more compact version of their IRS available
Pretty much a copycat of Mercedes benz common 5-link rear suspension that has been out of a few decades. You can find them in the junk yards at about 1/10th the price you'll pay for the AM overpriced and overengineered stuff. With that said, why on earth if the top camber arm bent and double bared into single mounts inner and outer? makes no sense.
Here is the Merc 5 link. I own a car with one of these. Very nice geometry.
Old Aug 23, 2016 | 09:36 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Originally Posted by SlickTrackGod
...why on earth if the top camber arm bent and double bared into single mounts inner and outer? makes no sense
Exhaust pipe clearance?
Is the Mercedes piece the one copied for the Mopar LX cars?
Old Aug 23, 2016 | 11:41 PM
On Probation
Yes Chrysler used the old Mercedes tried and true 5 link in all the 2000 years LX platform including they used it in the Crossfire. This suspension dates back to 1960's in the Mercedes prototype C111.
Just another fabricator stealing someone else's design.
ps- the upper curved camber arms are for frame clearance when trying to use this in an old school hotrod with frame rails. This rear suspension was designed for unibody cars. The exhaust will clear right under neath the center with plenty of ground height clearance since it is an independent rear suspension. The diff is fixed.
This is the reason I built a c-class Mercedes for my next play street car. This is beautiful suspension geometry from the factory and I only had to do a little bit of modifications to correct things when I lowered the car. The weakest link I have right now is the rubber bushing holding the rear subframe to the chassis- I will be milling aluminum bushings for this in the near future. I am currently putting a 6 sp manual into the car that I picked up from Europe- very crappy few choices in US spec cars from mercedes. This is the same suspension multilink setup used in the Mercedes DTM race cars.
This is a shot of my car.
It is a w202 Brabus. One of two I know of in the entire country. This kit is very rare.
Old Aug 24, 2016 | 05:51 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Being melodramatic again slicktrackgod? Would love to see you tell AME their just stealing other peoples designs..lol. Engineers couldnt possibly come up with the same solution to the same problems.
But yes, I see the similarities and identical nature of the setup.
BTW, teh AME version uses the newer Camaro center section and can be had with the SS, Z28, or ZL1 center sections.
Old Aug 24, 2016 | 06:51 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm still waiting for testing to conclusively show that an IRS system is going to perform better on the track (autocross, road race) than a solid axle.
Old Aug 24, 2016 | 10:07 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Some would argue predictability over conformity. Either way, I'd love to do some testing of my own ;P ;P
Old Aug 31, 2016 | 09:43 AM
prossi's Avatar
Here is some IRS testing. The Heidts/Hawks Silverstreak third gen came in second for the whole Super Chevy Shootout event, beat only by the roadster shop Rampage which is over a $500,000 full race car. It was in a field of other purpose built Pro Touring cars.
Silverstreak has no roll cage or chassis mods other than frame connectors. This is a car anyone can go and purchase the same parts and build.
http://www.superchevy.com/events/160...30th/#photo-10
Old Aug 31, 2016 | 09:45 AM
prossi's Avatar
Why try to make the Art Morrison fit when this one already does?
http://www.heidts.com/part/irc-301-k...ro-f-body-irs/
Old Sep 1, 2016 | 09:52 AM
92GTA's Avatar
Jesus, that Heidts piece looks like it weighs a ton!
Anyone know what either this or the AM IRS weigh?
Old Sep 1, 2016 | 10:21 AM
prossi's Avatar
Heidts IRS adds about 100lb of weight, which in itself isn't too bad..BUT most of it is sprung weight unsprung weight is reduced...and remember you are adding a ford 9" the housing is alu but the 3rd member is cast iron . if you used an alu 3rd member the extra weight would be much less
Old Sep 1, 2016 | 10:26 AM
92GTA's Avatar
Wow, that's less than I thought! Thanks.
Old Mar 25, 2017 | 05:47 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Actually I have used the art Morison set up before.. American has a thing for using corvette or Camaro parts.. there independent rear is a 5th gen third member as well as 5th gen spindles and if I remember correctly actually the entire rear end is based off of the 5th gen rear end
Old Mar 27, 2017 | 08:40 AM
prossi's Avatar
you are correct
Old Mar 28, 2017 | 09:41 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I've thought for a long time that the 5th gen rear could be modified (and naturally our car modified) to be used in a third gen. I actually think that because it has its own subframe that this kind of setup is better than the C4 setup, because all you need to do is tie the IRS subframe into our subframe to have more rigid support for the rear end.
cheves
Aug 11, 2016 10:25 AM
rmertus
Brakes
Jul 27, 2016 08:05 AM
Priya
Jul 21, 2016 09:22 PM
Rice01
Jul 6, 2016 01:57 PM
evan555222
Jun 10, 2016 11:24 AM
