Wonderbar Bracket Bolt
Old Mar 26, 2018 | 08:52 AM
SaintAggie's Avatar
I recently purchased a 89 IROC (my first third gen) and have begun doing necessary repairs. upon starting my most recent repair, replacing a broken wonderbar, I ran into a small but frustrating problem. The bracket that attaches the frame to the wonderbar on the drivers side is missing it's upper bolt. From what I can tell the bolt size is different than all the other bolts. Does anyone have any idea what size it is, or how I can find this information? Thanks in advance.
Old Mar 26, 2018 | 09:15 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Wonderbar Bracket Bolt
I think it is an M12 bolt.
Old Mar 26, 2018 | 09:23 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Wow, I've never seen a Wonderbar break.
Old Mar 26, 2018 | 09:24 AM
SaintAggie's Avatar
Is that different than the other bolts? I believe they were standard and much smaller? Thanks for the reply
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Really makes ya wonder....
Old Mar 26, 2018 | 09:26 AM
SaintAggie's Avatar
I will post a picture later. It was broken, welded, and broke again. Actually a bit concerning now that I think more about it...
Old Mar 26, 2018 | 09:40 AM
chazman's Avatar
Axle/Gears: BW 3.45
To answer your question, if I remember correctly, they are simply the sway bar bolts.
Old Mar 26, 2018 | 10:06 AM
SaintAggie's Avatar
The sway bar does bolt into this bracket, but the bracket bolts to the side of the frame rail under the steering gearbox. That's the bolt I'm wondering about. Sorry I was not more clear
Old Mar 26, 2018 | 01:21 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
They may be M10, but I am fairly sure it's an M12 for that bracket
Old Mar 26, 2018 | 04:52 PM
SaintAggie's Avatar
Awesome thanks Scooter!
Old Mar 26, 2018 | 10:03 PM
NoEmissions84TA's Avatar
If your car is breaking Wonderbars, you might want to remove the steering box and have a look at the frame. They crack right there.
Old Mar 27, 2018 | 04:21 PM
SaintAggie's Avatar
I absolutely will do that. Thanks for the advice. I do believe it was broke as a result of a collision somewhere in the cars past, but am not sure.
Old Mar 29, 2018 | 10:02 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
It's a M10 1.5 thread. 25mm or 30mm long will work
Old Apr 4, 2018 | 05:19 PM
SaintAggie's Avatar
This was it. Thanks!
Anyone ever seen This?
85Iroc-Z
Dec 16, 2010 10:05 AM
quisterio
Apr 15, 2008 06:43 PM
Joez88Camaro
Sep 25, 2004 10:16 PM
Hg
Jun 5, 2003 09:43 AM
