Loud creaking after installing sub-frame connectors
Old Jun 29, 2018 | 06:04 PM
TakingCharge714's Avatar
Car: 1984 Chevrolet Camaro Sports Coupe
Engine: V6 2.8L
So I got sub-frame connectors installed on my car and since then I hear a loud, metal creaking sound everytime
a person sits or gets off the car.
My question is if this is a normal thing, a case of cheap product, or something bad?
Old Jun 29, 2018 | 10:04 PM
NoEmissions84TA's Avatar
Re: Loud creaking after installing sub-frame connectors
So ....... how fat is she?
Old Jun 29, 2018 | 10:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Lmao
Old Jun 29, 2018 | 10:39 PM
Engine: V6 2.8L
XD
No fat chicks allowed in the car, and I myself weigh less than 150lbs.
Any slight weight causes the creak and at first I assumed it was the conversion from uni-body
that caused the new friction but if anyone knows different please let me know*
Old Jun 30, 2018 | 01:13 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
How were they installed? Fully welded in? Also were they welded in with the car on a drive on rack or in a garage on jack stands?
Old Jun 30, 2018 | 11:27 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
We need much more context other than "is this bad?", or "creaking."
Was the car ever in a collision? Is this in the front or back of the car? You are describing a noise occurring from ride height changes, so I'll guess the front.
IF the SFC's were installed properly, they provide rigidity to the frame structure, which forces the suspension components to do their job. So weaknesses in suspension components will now reveal themselves. Normal culprits are Sway Bar end links, improperly seated springs, bad struts, strut mounts or strut attachment points, or even cracked frame at steering box.
Old Jun 30, 2018 | 12:17 PM
If they're bolt-in, they're a joke.
Verify that the chassis is STRAIGHT (as an example, mine were installed on a race car jig), then weld them in. That largely cures the joke.
Old Oct 2, 2018 | 09:57 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Sounds like the car was not on the chassis when they were welded in
Old Oct 3, 2018 | 05:36 PM
Saxondale's Avatar
Car: 84 Z
Maybe is creaky supension now that car is stiffer, as mentioned above.
Old Oct 3, 2018 | 05:56 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
The car needed to be sitting on the tires when the SFC's were installed. Was it?
Old Oct 3, 2018 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Have somebody stand by the car and listen to where the noise is coming from.
Old Oct 4, 2018 | 01:04 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Check to see if all of the k member bolts are tight.
Old Oct 4, 2018 | 07:19 AM
Doesn't matter if the car is "sitting on the suspension" when SFCs are installed.
What matters is that the car is STRAIGHT. Not in a tweeeek of ANY sort: not lifted by 4 random points, not on uneven ground, not lifted on one side while sitting on the ground on the other, not not not not not not.
STRAIGHT. With the BODY plumb, square, and level. That's all that matters. "Suspension" is TOTALLY UNRELATED to them. It doesn't even have to be present, let alone in effect.
As said, mine were done with the body - minus suspension, engine, interior, and abuncha other stuff... it was part of a larger project being done at the same time - bolted down on a race car jig. Securing the body to a frame straightening fixture and trammed straight would work well also.
Ignore the myths about "suspension loaded". That isn't true.
Old Oct 6, 2018 | 02:29 AM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
Whoever installed them did it incorrectly
Old Oct 6, 2018 | 10:20 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
Was the car ever lowered?
Crusin' 1980's
May 18, 2011 09:54 PM
vbMike
Oct 15, 2007 02:41 PM
camaro_boy123
Aug 11, 2007 09:32 PM
MKnight
Mar 10, 2006 08:54 PM
PALM BEACH IROC-ER
Dec 23, 2001 01:45 AM
