UMI releases 3rd Gen front sway bar and relo brackets
Old Aug 29, 2018 | 01:46 PM
UMI Sales's Avatar
1982-1992 GM F-Body Front Sway Bar, 35mm
UMI P/N 2117
$249.99
2117 Catalog page
Application:
1982-1992 Chevrolet Camaro
1982-1992 Pontiac Firebird
(All models)
UMI 2117 Front Sway Bar kit
UMI’s 35mm (1-⅜”) solid front sway bar is designed to reduce body roll and increase responsiveness and cornering capabilities of the 3rd Gen. UMI’s front sway bar is 22% more rigid than the hollow 36mm, 1LE Front sway bar. Each kit includes heavy duty relocation brackets that improve clearances around the steering system and strut. Increased clearance allows for a greater variety of options with struts, including adjustable style struts. Relocation allows the use of upgraded billet sway bar mounts (sold separately). The sway bar kit includes heavy duty end links, large diameter poly sway bar bushings, zinc plated clamshells, and all required hardware. Manufactured in the USA from 1-⅜" high carbon tubular steel, CNC bent and formed to ensure maximum strength and performance. Sway bar is available bright red or gloss black powder coat for a durable, long lasting finish.
Installation Note: Sway bar kit includes spacers to allow proper installation with UMI’s front wonder bar, P/N 2030. Spacers may work with other brand wonder bars as well. P/N 2030 front wonder bar is optional and not needed to complete the sway bar installation.
Features:
1-⅜” (35mm) CNC bent 4140 chromoly construction.
Perfect for corner carving while maintaining ride comfort and flatter cornering.
Excellent multi-purpose bar.
Fits in stock location using supplied brackets.
Manufactured in the USA.
1982-1992 GM F-Body Front Sway Bar Relocation Brackets
UMI P/N 2119
$49.99
2119 Catalog page
Application:
(All models)
UMI 2119 Relocation Bracket kit
UMI’s heavy duty relocation brackets improve clearances around the steering system and struts by moving the mounting points slightly forward. Increased clearance allows for a greater variety of options with struts, including adjustable style struts. Relocation also allows the use of UMI’s upgraded billet sway bar mounts (sold separately). This is an excellent upgrade for factory brackets that are rusted or breaking from competition use.
Installation Note: Relocation brackets eliminate the offset factory sway bar clamshell and now use off the shelf sway bar bushings and mounts. Factory sway bar mounts will not work with new sway bar relocation brackets. Relocation kit also includes spacers to allow proper installation with UMI’s front wonder bar, P/N 2030. Spacers may work with other brand wonder bars as well. P/N 2030 front wonder bar is optional and is not needed to complete installation.
Features:
⅜” thick steel with laser cut construction.
Use with factory or other aftermarket sway bars including UMI 2117.
Used to remove the offset sway bar mount and replace with the more common straight style.
Correct mounting hardware included.
Includes spacers to allow installation of most front wonder bars.
Powder coated black for a lasting finish.
Manufactured with pride in Philipsburg, PA- USA.
Old Aug 31, 2018 | 10:20 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: UMI releases 3rd Gen front sway bar and relo brackets
[QUOTE=UMI Sales;6247513] UMI’s front sway bar is 22% more rigid than the hollow 36mm, 1LE Front sway bar.
[QUOTE]
I'm not being combative, I just want to know the figures behind the claim.
Do you know the torsional stiffness in lb/in of both bars? How do you come up with "22% more rigid?"
Old Aug 31, 2018 | 10:24 AM
UMI Sales's Avatar
1LE - 506 lb/in
2117 - 616 lb/in
Old Aug 31, 2018 | 10:27 AM
UMI Sales's Avatar
Those numbers give 18%. Since there is a range I probably should have said "approximately 20%".
Old Aug 31, 2018 | 03:10 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
That's ok.
Thank you
Old Sep 1, 2018 | 08:27 PM
RT66ProTouring's Avatar
Car: 1991 Camaro
Engine: 5.3L LS
I guess I'm missing something here. Please post a pic to illustrate what you're saying here. Thanks.
Old Sep 1, 2018 | 09:53 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Check out the catalog page. They have a picture showing the factory offset mount.
http://umiperformance.com/catalog/in...oducts_id=1130
Old Sep 1, 2018 | 09:57 PM
Car: 1991 Camaro
Engine: 5.3L LS
Thanks!
Old Sep 4, 2018 | 12:29 PM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
1LE - 506 lb/in
2117 - 616 lb/inThose numbers give 18%. Since there is a range I probably should have said "approximately 20%".
Actually, 506 x 1.22 = 617 and 506 x 1.21 = 612 so 22% is an accurate increase. More accurately, based on 616 and 506 it's a 21.73913043478261% increase
https://www.skillsyouneed.com/num/percent-change.html
Old Sep 6, 2018 | 08:33 AM
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
To add to this, the 1LE bar would be 18% LESS rigid than this UMI bar. The UMI bar is 22% MORE rigid than the 1LE bar. Either is correct. Isn't math fun?
Old Sep 11, 2018 | 03:45 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
It would be nice if you combined the relocation bracket into the steering brace/wounder bar.
Beater79TA
Aftermarket Product Review
Feb 26, 2019 08:41 AM
Steven6282
Mar 23, 2012 02:19 AM
irocstang
Group Purchases
67
May 10, 2006 02:42 PM
