Suggestions on dropping my ride
Car: 84 Camaro Z28
Engine: 305HO
Transmission: 5 Spd
Axle/Gears: 373 Gears
Hey gang... I have a stock 84 z28 with a air suspension in the rear from the previous owner. I'm looking to get rid of some of the wheel gap in between the front and rear tire and the fender wells. The back I suppose I can let air out of the shocks to lower, but the front I would need to change the springs. I'm looking to drop about an inch... nothing drastic that would give me problems with turning and tire rubbing. Should I do both front and rear springs, or just front? Also what manufacture do I go with? Any suggestions would be greatly appreciated. Thanks!
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Suggestions on dropping my ride
Coilovers is the best way to go so much adjustable and if you go with double adjustable just more fine tuning
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The best adjustable setup for these cars is a weight jack setup since they are no designed or setup properly for coilovers. Even basic lowering springs work just fine for a bit less money. Eibach prokit or sportlines are the common ones, there are others too. Prokit is about an inch drop.
If you actually have rear air shocks, take them out before you break something, seriously.
Engine: LQ4 ls 6.0
Ive never had weight jacks Ive had lowering springs and coilovers and no valving has nothing to do with ride height I like the option of adjusting my ride height and I never said they were magical
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Umm no. Coilovers are an expensive buzz word and are not something magical. Aside from packaging the two parts closer together, a conventional spring and shock do the same thing. Double adjustable is shock valving and has nothing to do with height adjustment.
I Agree
lowering springs are ok for looks but performance wise front spring rates are similar to stock Irocz rates and rears are all progressive which is fine for cruising but suck when push hard
but weight jack system either put together yourself and or pre made kits with springs are the way to go , coilovers you are limited in front wheel size as usually the widest is about a 9.5
adjustability is with the shocks you get and many will say Koni are the best which they are and AGX are not bad either for price
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Are dropped spindles still available for our cars? It does the job of lowering the car, but leaves suspension travel and spring rates stock.
They were a thing back in the day IIRC, but I've not looked into them in decades.
Engine: LQ4 ls 6.0
I Agree
you just stated it was the best tho ?
Engine: 305 to 350
Axle/Gears: 10 Bolt
I ran have ran 10 and 10.5 up front even tried a 11 lol and with my specs on wheels it was close to strut with right set of wheels and spacer It can work but coil overs upfront eat up some space I haven't look into them and or cared too as performance doesn't justify the price for me
I would like to see pics of your clearance upfront in your thread only see the 9.5 up front with 245s
so others can have picture reference of clearance
Engine: 305 to 350
Axle/Gears: 10 Bolt
can use extended ball joint
Engine: LQ4 ls 6.0
tight fit I would assume
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: LQ4 ls 6.0
ive done this setup I will be installing 8 inch springs
Engine: 305 to 350
Axle/Gears: 10 Bolt
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
dennisbernal91z
Nov 7, 2017 02:13 PM
Kandied91z
Sep 20, 2008 09:24 AM
