help with lowering
Old Dec 6, 2018 | 11:11 AM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
help with lowering
I have a 88 gta
I cut 1 coil out of the front springs a few years ago
and now I want to do that to the rear
I never got a alignment
but I was wondering how I do it and how I align the rear??
ty
Old Dec 8, 2018 | 08:32 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: help with lowering
Originally Posted by bensbaby
I have a 88 gta
ty
I would only cut a coil a coil from a new OE spring. The old springs are worn and may have a longer suspension travel than a new spring would if shown the same force. If you are lowering the front you really should get an alignment, especially if it's been a few years since you have. I would search out in your area (say an hours drive) for any shop that will offer lifetime alignment specials. The rear end if left with OE parts does not need aligned and would only need aligned if you started to use adjustable length parts. The single or double adjustable control arms could angle the rear end if they are not exactly the same length. This happened to me when I took my Camaro to the GM dealership (wow, did they have a nice alignment rack!) and I found out my rear was pointed towards the passenger side by 1/4 of 1°. So you should be able to save some money by only buying a 2 wheel alignment.
davidopliger
Feb 3, 2025 09:30 AM
stratman2ssrs
Jun 30, 2018 01:45 PM
chuck6860
Jul 23, 2002 09:36 AM
Karps TA
Mar 1, 2002 04:20 PM
un4givin89
Dec 28, 2001 08:52 AM
