Help !! Ball Joint
Old Oct 17, 2019 | 06:58 AM
oldboy68's Avatar
Help !! Ball Joint
Hi Guys, This will sound crazy to most of you,but I am just an amateur mechanic needing help please. I am trying to replace my shocks and bottom swivels, I went on Rockauto site and ordered part it listed a few ball joints, but when i received parts and took old part out they are different, drrrr yes my natural reaction is i got wrong part, See photo attached old part and new one has splines ? can you clever guys confirm I have ordered the wrong parts, I have a 1986 Camaro 305 z28 I may have to re order, thanks in advance
Clearly they are different but on rock autos i typed in my car and these parts came up and I assumed they would fit ?
Old Oct 17, 2019 | 07:16 AM
oldboy68's Avatar
Re: Help !! Ball Joint
These are the part numbers given 2 X MEVOTECH ( MEV MK6145T BALL JOINT (80708.80.3590) $13 .90 EACH
Old Oct 17, 2019 | 07:39 AM
Looks fine to me.
The "splines" cut into the hole as they press in, helping to grab... the hole is often distorted and an exact replacement would no longer fit tight.
Old Oct 17, 2019 | 08:28 AM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
The part is correct. All aftermarket lower ball joints have those "splines".
Old Oct 17, 2019 | 01:02 PM
oldboy68's Avatar
Looks fine to me.
That would make sense as the old ball
joint, only needed a couple of lite taps and it dropped out. Cheers
Old Oct 17, 2019 | 01:07 PM
oldboy68's Avatar
Thanks Rock Autos did have a few that did not have the splines which is what worried me hence this post
Old Oct 18, 2019 | 06:01 AM
oldboy68's Avatar
Thanks Guys for the advice, as you can see one fitted, just got put strut back in now
Old Oct 18, 2019 | 08:03 AM
Old Oct 19, 2019 | 06:35 AM
I should have said "nearly" all aftermarket parts.
400Z28Racer
Aftermarket Vendor Review
89
Oct 26, 2006 12:51 AM
bobdole369
Mar 25, 2006 07:21 PM
1986redbird
Mar 27, 2003 06:49 AM
