9" torque arm mount
Subscribe
Nov 2, 2019 | 08:37 PM
I recently picked up a 9" that is supposed to bolt right into a thirdgen. However, the torque arm mount looks sketchy. I am wondering if this will work or not
Reply 0
Nov 2, 2019 | 10:13 PM
Re: 9" torque arm mount
Yikes...
Reply 0
Nov 2, 2019 | 10:15 PM
Quote: Yikes...
Definitely looks sketchy. I will probably just get a currie one and weld it on there, or take it to Moser. I can't complain much though. It was $200
Reply 0
Nov 3, 2019 | 09:47 AM
I wouldn't run that mount. Get the mounts that weld on to the top and bottom of the housing and have a shop weld them on. Unless you have a welder in which case make em yourself for a few bucks if you have ample time.
Reply 0
Nov 5, 2019 | 07:30 AM
Quote: I wouldn't run that mount. Get the mounts that weld on to the top and bottom of the housing and have a shop weld them on. Unless you have a welder in which case make em yourself for a few bucks if you have ample time.
Would you get the currie enterprise one? Or the Moser one? Both would end up costing around the same when said and done. The moser looks a little more beefier, but it may not hold up as well.
Reply 0
Nov 5, 2019 | 12:27 PM
I've had the moser 9" in my car for over 20yrs. It's doing fine.
Reply 0
Nov 5, 2019 | 01:46 PM
Quote: Would you get the currie enterprise one? Or the Moser one? Both would end up costing around the same when said and done. The moser looks a little more beefier, but it may not hold up as well.
How would the moser one not hold up well? It's a massive chunk of cast iron. It will outlast the car.
Reply 0
Nov 5, 2019 | 03:25 PM
Wow cray cray
this is also a option
https://www.quickperformance.com/Tor...d_p_15969.html
Reply 0
Nov 5, 2019 | 09:06 PM
I have that mount from Currie in my garage $100.00 plus shipping and its yours. I have it in a box but can dig it out. I never used it.
Reply 0
Nov 5, 2019 | 09:37 PM
I have this one from QP
https://www.quickperformance.com/QP-...xles_p_40.html
Had it for 9 years with no issues
Reply 0
Nov 5, 2019 | 11:24 PM
Wow that's the best deal I've seen for a build-it-yourself type rear end. The axles, housing and Torque arm mount all for $1K.
Reply 0
Nov 6, 2019 | 10:35 AM
Quote: How would the moser one not hold up well? It's a massive chunk of cast iron. It will outlast the car.
https://www.thirdgen.org/forums/tran...m-bracket.html
However, I am still leaning towards the moser after reading that. It seems quite a bit stronger and has more points where it is connected to the housing. I emailed moser on monday, and am still waiting to hear back from them.
Reply 0
Nov 6, 2019 | 12:08 PM
damn that's good deal
Reply 0
Nov 6, 2019 | 03:55 PM
That's a old bracket, the newer design is a one piece cast iron unit. I have both.
Reply 0
Nov 6, 2019 | 07:20 PM
+1 on the QP bracket! I have one for my 9"
Reply 0
Nov 7, 2019 | 10:43 AM
So judging by the amount of people that have both, either one would be sufficient?
Reply 0
Subscribe
