Coil Spring Rubber Seats F & R
Old Jan 10, 2020 | 04:56 PM
Zarlor's Avatar
Hello,
I have been searching the forum, but I'm only finding 8-10 year old posts....
I can find front upper spring rubbers but nothing for the rear.
Any ideas? No GM parts seem to be available.
Any ideas?
'89 Formula
Old Jan 10, 2020 | 05:29 PM
Drew's Avatar
Re: Coil Spring Rubber Seats F & R
Junkyard? Ebay? Classifieds in the "wanted" subforum? Slit heater hose and snap over the top coil.
https://www.thirdgen.org/forums/engi...ension-wanted/
Old Jan 11, 2020 | 06:46 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Use heater hose on the first coil
Originally Posted by Zarlor
Hello,
Any ideas?
'89 Formula
Old Jan 12, 2020 | 12:05 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
What about 4th gen pieces? Are they the same?
Old Jan 13, 2020 | 04:13 PM
GeneralDisorder's Avatar
I did quite a bit of searching on this and my front upper rubber were shot. I had it apart and didn't want to wait so I just wrapped the top and bottom of the spring in electrical tape and put some water-proof grease in the pockets. No issues.
In the rear you can typically just reuse the stock ones. You do need those and I have just put them back in each time I've dropped the rear axle.
4th gen are not the same and on the rear they will lift the car an inch for sure. I've seen pics and discussions of that.
GD
Sinfulrelations
Dec 28, 2013 01:07 PM
skinny z
Jul 29, 2010 10:26 AM
vonbeck265
May 17, 2010 10:36 AM
Hg
Aug 11, 2003 12:01 PM
Karps TA
Feb 8, 2002 08:40 PM
