Power Steering Lines
Old Nov 30, 2020 | 06:11 PM
tschetterb's Avatar
Car: 1983 Camaro Z28
Engine: 350 LT1
Transmission: 4 speed Auto
Axle/Gears: 4.10
I am replacing my steering gear box and the return hard line bent and cracked while removing the nut. When I go to replace the line, should I replace with an 83 return hose/line or go with a 93? It’s a 93 350 swapped 83 z28.
Old Nov 30, 2020 | 07:36 PM
Re: Power Steering Lines
Return hose is usually just that; hose. As long as your 93 pump has the same size hose barb as your car's steering gear, yerbasic piece of hose will work. Should be available in bulk form; maybe a little pack with 3' or something, also sold as transmission fluid cooler hose. Don't try to use any kind of fuel line.
Old Nov 30, 2020 | 08:11 PM
NoEmissions84TA's Avatar
You also might want to consider using fuel injection style hose clamps. They don't bite into the hose like regular hose clamps do.
Old Dec 1, 2020 | 06:41 AM
tschetterb's Avatar
Engine: 350 LT1
Axle/Gears: 4.10
Excellent. The one I found at my local parts store is like $16. So far every job I’ve tackled on this vehicle has been included finding several other problems or inadvertently creating other problems. It’s been a fun learning experience. Thanks for the help!
The most current issue is the gearbox is stuck to the pitman arm and of course the puller I “rented” is to small.
Old Dec 1, 2020 | 09:34 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Return line is low pressure. The factory lamps are just spring loaded.
Other than a leak and a mess, a small drip is no worries as long as the reservoir doesn't go too low.
High Pressure line? Now THAT is where you have to be SUPER careful. That line runs like 1500psi to 2000psi I think. A pinhole leak from there is the same thing as sticking your hand in a band saw. No joke with that stuff.
86iroc504
May 2, 2020 12:02 AM
bigchief
Aug 7, 2010 10:16 AM
irocboy8292
Jan 13, 2009 07:20 PM
FastPhoenix84
Jul 28, 2008 09:34 PM
astroglyph21
Jun 19, 2008 08:13 PM
