Choosing a 36mm sway bar bushing
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
I'd like to hear peoples thoughts and what they've used, any other options out there?
Top Down Solutions
Spohn Performance
Top Down Solutions
Spohn Performance
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Choosing a 36mm sway bar bushing
Factory one. Thats what TDS sells, just powdercoated.
One of the ES or Prothane ones that's 1-3/8". That being the nearest Imperial equivalent to 36mm that's no larger than 36mm.
I'd go with the 9173 if it was me... the thicker poly layer will transmit a bit less road harshness to the chassis. Not a big difference though, either of those will work.
Engine: 5.7 HSR
Yeah, the whole poly part is thicker, and the bracket is bigger around to accommodate it. But yes, it looks like the bracket for the one is flat, and the other has a slight bevel. It might also be the one intended for heavier duty applications like trucks; ones for cars won't take the extra load that a truck puts on it.
Engine: 5.7 HSR
Engine: 5.7 L98
As you called it, only 2 places carry it when I looked. I have the Spohn ones for my GTA but have not installed yet, focusing on the rear end links and bushings once the axle is painted this week. They look like quality pieces but so did Lons at TDS but Spohn had a free shipping deal.
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
When I rebuilt the front end in my '89 IROC this spring, I went with Spohn for my 36mm sway bar bushings. I was and still am very happy with this choice. They installed with no trouble and don't squeak at all so far. Car handles great.
